Old 01-15-2013, 05:58 PM   #1
thewrai6th
3 speed column shifter stuck when it's cold outside
Every morning I go out to start my truck; if it's below about 40 degrees, I can barely pull the shifter up between R-1. Feels like I'm going to bend or break the shifter.
I tried hitting the column with WD40, no luck there. Tried lubing it up with good old grease and still no luck.
It seems like the metal is getting cold enough to shrink and bind when it freezes overnight. Is there something I can loosen? Tighten? Lube?
My next step was going to be graphite spray.
1969 Stepside restoration
thewrai6th is offline   Reply With Quote
Old 01-15-2013, 06:01 PM   #2
64fleetside
Re: 3 speed column shifter stuck when it's cold outside
The old grease inside is getting stiff. Only way I know to properly fix it is disassembly of the column, clean out old grease, lube up with fresh stuff.
64fleetside is offline   Reply With Quote
Old 01-15-2013, 06:06 PM   #3
ubtripn
ubtripn's Avatar
My 66 3 on a tree had bushings that I used to lube under the hood on the drivers side that would also bind when going from 1st to 2nd. On my 68 I shot some penetrating lube through where the arm enters the column and it loosened things up. May or may not work.
ubtripn is offline   Reply With Quote
Old 01-15-2013, 06:28 PM   #4
68gmsee
Active Member
68gmsee's Avatar
There's a long tube that slides up and down the steering column to shift the levers. In the factory it was lathered up with grease which after 40 years dries to a thick sticky substance.
In some cases you can get by spraying the h3ll out of with WD40 or other lubricant/solvent but be sure and protect the floor board and garage floor. In my case I had to take the column off and remove all the old stuff and relube. I had to basically clean out chunks of waxy hard grease.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 01-15-2013, 10:10 PM   #5
cericd
cericd's Avatar
Good to see this post. I bought my 70 C10 back when it was warm and when the first cold snap came I took the truck out and not being familiar with a 3-on-the-tree, I thought something was broken. But you summed it up perfectly, it seems like I'm going to bend or break the gear shift lever to go from R to 1st. Looks like I need to clean out the old grease on mine too.
cericd is offline   Reply With Quote
Old 01-16-2013, 12:16 AM   #6
GRX
GRX's Avatar
x3 three on old column grease. My 3 tree used to do that.
A Hurst floor shift conversion kit solved it quite nicely.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 01-16-2013, 10:10 AM   #7
cericd
cericd's Avatar
Hey , thewrai6th I ran across this thread http://67-72chevytrucks.com/vboard/s...d.php?t=215307 and it seems to have some good 3OTT info. Check out the 3rd sentence of the original post.
3 on the tree, shifter, stuck
