Old 01-17-2013, 11:05 PM   #1
travz500
travz500's Avatar
did 64 have factory powersteering?
I have a 64 with powersteering I bought the truck for parts and I noticed it had power steering and the box physically looks like my 87 steering box but has a different bolt pattern than the newer boxes so I am assuming it is original? but not sure
travz500 is offline   Reply With Quote
Old 01-18-2013, 01:24 AM   #2
yelmer
Re: did 64 have factory powersteering?
the 64 was a slave cylinder type no hoses go into the steering box
yelmer is offline   Reply With Quote
Old 01-18-2013, 01:26 AM   #3
Captainfab
60-66 Nut
The '63-'66's that had factory power steering, were actually power assist steering. The pitman arm attached to a valve assembly which controlled a hydraulic cylinder attached to a bracket off of the back of the steering box, and to the draglink. This is the same setup that was used on the Corvette's for many years. I believe it was used thru the end of the production of the C3's.
Old 01-18-2013, 01:04 PM   #4
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Old 01-18-2013, 04:33 PM   #5
Slow Build
Slow Build's Avatar
Picture of that setup on a junkyard truck.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 01-18-2013, 05:38 PM   #6
RANDY COX
RANDY COX's Avatar
that's pretty neat..
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 01-18-2013, 09:18 PM   #7
earl84
I have some of these parts hanging off my truck but not the whole system. I don't think I am going to go to the trouble of trying to get it fixed since I want to eventually slide a 73-87 crossmember in and get power steering and disk brakes. Was this system very good?
earl84 is offline   Reply With Quote
Old 01-18-2013, 09:21 PM   #8
yelmer
i have it on both my 66s i love it , but they are prone to weep fuild
Old 01-19-2013, 06:26 PM   #9
62ss409
My 65 doesnt have a slave cyl. set up. I am pretty sure its original. It only has hoses from pump to steering box. Are you sure all 63-66 had slave cylinders?
62ss409 is offline   Reply With Quote
Old 01-20-2013, 01:33 AM   #10
yelmer
yes the factory unit from 63-68 was a slave type unit
Old 01-19-2014, 09:38 AM   #11
trucktony
I've got one on my 66
Want to convert to the powersteering gear set up because my old one is leaking to much.
As I can see it now I will have to use another steering link/bar because the one now is integrated with the powerslave/pitmanarm unit.
Does anyone know if this is hard to do and which one I can use for the conversion?
Does a 67-72 steering link/bar also fit?
Does anyone know if there's a rebuild kit for the whole slave systeem?
Is it Identical to the C3 corvette setup?
Thanks Tony
trucktony is offline   Reply With Quote
Old 01-19-2014, 10:30 AM   #12
yelmer
I used the corvette parts they are the same except ffor the hoses . The valve and pump and piston are the same
Old 01-19-2014, 11:06 AM   #13
LT1 Burb
LT1 Burb's Avatar
Picture of mine rebuilt, The Truck Shop carries all the parts to do.
LT1 Burb is offline   Reply With Quote
Old 01-19-2014, 12:02 PM   #14
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Boy this ol school setup is sweet! Mine was just the typical manual steering.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 01-19-2014, 12:26 PM   #15
Rich 5150 69
Rich 5150 69's Avatar
We use to put a ( shot glass ) full of brake fluid in with the power steering fluid to swell the seals back up....!
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 01-19-2014, 03:13 PM   #16
trucktony
Looking real good
But I'am going for the newer after market steering conversion with the 69-87 steering gear( with the 3,5 gear ratio)
Do you know if I can use the same track rod or do I need a standard one
(the ones used without the slave steering power adapters)
If I would need another one which one will fit?
Are there multiple choices to make a search easyer?
Will be rebuilding the old slave powersteering just for fun and keep it so the truck stays complete.
Thanks for all your reply's
Keep them coming
Your a big help
Tony
Old 01-20-2014, 02:35 AM   #17
Captainfab
60-66 Nut
You will need a draglink for a '63-'66 truck if you are going to upgrade to the integral power steering box. The '67+ draglink, I believe has a different size taper for the tierods. This might be a good time to upgrade to disc brakes at the same time. I always recommend using the '73+ steering linkage along with the disc brake upgrade. That way all the steering and suspension is of the same vintage, and easy to remember when asking for replacement parts. plus then you don't need those $$ aftermarket aluminum tierod adapters.
Old 01-20-2014, 04:39 AM   #18
trucktony
Thanks Captainfab
That's worth considering
I will let you know which way we went
Does a 73+ fit the A arms of a 63-66 truck?
So I can go for a salvage yard conversion or do I have to get aftermarket parts to make it a whole set?
Thanks again
Tony
Old 01-20-2014, 12:16 PM   #19
Captainfab
60-66 Nut
No, the '73+ tierods will not fit the '63-'66 spindles. Yes you can do a complete disc brake swap using '73-'87 C10 components, whether from a wrecking yard or a donor truck from an individual. You do not have to use aftermarket parts for a disc brake conversion. There are a few threads all about this in the '60-'6 FAQ Index found at the top of the page.
Originally Posted by trucktony View Post
Thanks Captainfab
Thanks again
Tony
Old 01-21-2014, 05:30 AM   #20
trucktony
Thanks again for all the info
I'll put it to a hold because the disc brake conversion also sounds good to me
Then I don't have to search for a 63-66 track rod for my powersteering conversion.
And maybe I can sell the factory powersteering kit as a Whole to someone how wants to stay original
Old 10-09-2021, 10:53 PM   #21
Brim
Brim's Avatar
I'm wondering the same thing because I am replacing my pressure line on my 64 Fleetside and it does connect on the steering box. It does not have the pitman arm attached to a valve assembly which controlled a hydraulic cylinder attached to a bracket off of the back of the steering box, and to the draglink like Captain Fab said so I'm wondering if it is original or was added.
Came with the truck like this when I bought it. Previous owner has since passed so no luck there.
-Mark
Brim is offline   Reply With Quote
Old 10-10-2021, 05:47 AM   #22
The Rocknrod
Moderator
The Rocknrod's Avatar
-Mark
It's aftermarket. So the hoses I recommended in your other hose thread were for an OEM unit. Here is a thread on that and you'll probably see your type of gear box in there also. http://www.67-72chevytrucks.com/vboa...d.php?t=332923
Old 10-10-2021, 11:52 AM   #23
Brim
Brim's Avatar
Thank you very much sir. About to head out to Auto Parts now...
-Mark
