Old 01-28-2013, 10:21 PM   #1
jed971959
Jed's 49 3100
Hi everyone
Started my build a couple of years back
it's a 1949 5 window chevy p /u with 60 years of rust
pic from ebay
Attachment 1050950
got it from texas and had it shipped up to port huron
put it in storage there and waited to get my passport
a few weeks later we went down and picked it up
Attachment 1050993
the fun starts
the first thing that didnt look good
then some more good finds frame has big bad holes
so was thinking what to do get a frame or do a s10 frame swap
well being cheap and having a 97 blazer with a rusted out body sitting
in my driveway you know where this is going
jed971959 is offline   Reply With Quote
Old 01-28-2013, 10:25 PM   #2
jed971959
Re: Jed's 49 3100
here are the first 2 pic don't know what happened
Old 01-29-2013, 10:50 AM   #3
jed971959
Re: Jed's 49 3100
The blazer only sat in the driveway when the wife was not driving it but I was looking for a replacment. I work on the truck in the summer because of the small garage on the house 12X20
it's time to take a good look at it now
Find the common rust spots floors,inner&outer cowl,cab corners then
for the unexepted above corner windows,back of cab at belt line,inside panel around rear windows
started to take it apart
seen on a site about striping parts with a batt charger this is what I started with
Name:  30 gal tank 2.jpg
here is the part after cleaning and a little wire brushing
Old 01-29-2013, 11:18 AM   #4
jed971959
Re: Jed's 49 3100
This is the stripping tank I ended up with after going a little bigger 4 or 5 times tank with front fender in it
Name:  fender in tank (3).jpg
after cleaning some parts it looks like this
Name:  fender in tank 2 time.jpg
Half the hood
Name:  hood in tank.jpg
I would leave the parts in the tank 1to7 days removing them to pressure wash
the converted rust off every couple of day. I think this help with the time it took to clean the parts
inner fender before pressure washing it
Name:  in fender 3.jpg
Old 01-29-2013, 03:57 PM   #5
jed971959
Re: Jed's 49 3100
inner fender after pressure wash and a little wire brishing
Name:  inner fender and suport.jpg
Name:  in fender 9.jpg
few parts hanging around drying
Name:  fr rad painted 2.jpg
Name:  inner fenders primed.jpg
Name:  hanging parts painted.jpg
Old 01-30-2013, 11:48 AM   #6
jed971959
Re: Jed's 49 3100
a few more pic
Name:  left cowl 04.jpg
Name:  left cowl 4.jpg
Name:  left floor 02.jpg
Name:  left side 1.jpg
Old 01-31-2013, 01:40 PM   #7
jed971959
Re: Jed's 49 3100
Attachment 1052469
Attachment 1052470
Attachment 1052471
Attachment 1052472
Attachment 1052473
Last edited by jed971959; 01-31-2013 at 01:41 PM. Reason: wanted pic here not link
Old 01-31-2013, 01:49 PM   #8
jed971959
Re: Jed's 49 3100
Can someone tell me why some times I post pic's other times a link to pic
what did I do wrong
Old 02-01-2013, 10:04 AM   #9
jed971959
Re: Jed's 49 3100
2nd try at posting pic
right side cowl and floor
Name:  right cowl 2.jpg
Name:  right side floor 5.jpg
Name:  right side floor 2.jpg
Name:  right side floor 4.jpg
took the truck to the car wash and spent $10 in the vac
trying to clean what the last renters left
this was after pluging up there 2 vac had to finish it at home
Old 02-01-2013, 02:49 PM   #10
jed971959
Re: Jed's 49 3100
Name:  left door 1.jpg
Name:  cab rear inner.jpg
Old 02-01-2013, 03:04 PM   #11
jed971959
Re: Jed's 49 3100
belt line
drivers door post
my portable sandblasting booth
rented a 18 cfm gas compresser for the weekend to do the cab
rained allday sunday but got most of it done
Old 02-01-2013, 03:18 PM   #12
jed971959
Re: Jed's 49 3100
truck in my garage for the winter
got this stiff from home depot hope it help with the noise
new rear panel needs weld in yet
first coat of fiber glass
Old 02-01-2013, 03:27 PM   #13
jed971959
Re: Jed's 49 3100
trying for a better door gap
Old 02-01-2013, 03:37 PM   #14
jed971959
Re: Jed's 49 3100
removing the cab from old frame should have had truck in backwards
wouldn't have to go up over the engine
Name:  cab off 2.jpg
Name:  cab off 3.jpg
Name:  cab off 4.jpg
body work done over the winter forgot to take any pic
Name:  cab off 6.jpg
cab primed
Name:  cab rust bullet.jpg
Old 02-01-2013, 03:54 PM   #15
jed971959
Re: Jed's 49 3100
97 jimmy tear down
cab seating on jimmy frame maded my own mounts from
4X4X1/4 sq tubing with the jimmy frame mounts trimmed down
to fit on top so I didn't have to drill ony holes of the mounting
rubber
Name:  cab on jimmy frame 2.jpg
Old 02-01-2013, 04:14 PM   #16
jed971959
Re: Jed's 49 3100
think I my need a beer or read before I post
should have read like this
so i don't have to drill any holes for the mounting rubber bushing
Old 02-01-2013, 07:36 PM   #17
jed971959
Re: Jed's 49 3100
Old 02-01-2013, 10:43 PM   #18
tobins 52 gmc
tobins 52 gmc
Re: Jed's 49 3100
looking good
tobins 52 gmc is offline   Reply With Quote
Old 02-02-2013, 12:03 PM   #19
jed971959
Re: Jed's 49 3100
getting it ready to paint the roof and rear cab
Old 02-02-2013, 12:23 PM   #20
jed971959
Re: Jed's 49 3100
put the flat bed on to get it on the road
will put the bed on when it done
rad and fan installed
rads a 1966 mustang 3row
Old 02-02-2013, 12:40 PM   #21
jed971959
Re: Jed's 49 3100
making end cap for steering shaft
Old 02-02-2013, 12:54 PM   #22
jed971959
Re: Jed's 49 3100
shafter from the 49 made to work on a 4 speed auto
gives the shifter a park have to pull handle backto get out of park
Old 02-02-2013, 01:17 PM   #23
jed971959
Re: Jed's 49 3100
used a 2 wire fan motor from 02 blazer
changed the wires - to power this will make the fan run the right way
making the wireing harness for under seat fuse box and relays
Old 02-02-2013, 06:19 PM   #24
jed971959
Re: Jed's 49 3100
Old 02-02-2013, 08:39 PM   #25
chev3600
chev3600's Avatar
Re: Jed's 49 3100
Gauges are looking nice. Is that a couple of aftermarket gauges fitted in the original housing?
1949/1954 with LS swap-yeah!
http://s260.photobucket.com/albums/i...0/AD%20trucks/jumbled mess of unorganized photos
chev3600 is offline   Reply With Quote
