Old 02-04-2013, 03:06 PM   #1
blackbeaSSt
**SIGH** On to the next delima: lean problems!
so now im getting a p0171 and p0174 code thrown at me on the 02 burb. i see there are numerous possibilities of what this could be.
i've changed out the o2 sensor within the past 18 months so im not sold its that. i also see it could have something to do with the fuel pump/filter/etc. i will say that here recently if we let the gas get down to less then a quarter of a tank it seems harder and harder to start. to the point of 2 or 3 times last year it wouldn't start at all unless i put more gas in it.
before i go and drop a lot of money into dropping the tank and replacing the pump, is there anything else that i should try before i hand it off to my mechanic?
blackbeaSSt is offline   Reply With Quote
Old 02-04-2013, 08:41 PM   #2
bighaas79
Re: **SIGH** On to the next delima: lean problems!
Vacuum leak or incorrect readings from maf sensor, either from not working correctly or being dirty.
bighaas79 is offline   Reply With Quote
Old 02-05-2013, 09:06 AM   #3
blackbeaSSt
is it suggested to clean, or replace the maf?
Old 02-05-2013, 10:37 AM   #4
Easyeight
Intake manifold gaskets
Easyeight is offline   Reply With Quote
Old 02-05-2013, 11:24 AM   #5
blackbeaSSt
yeah thats another thing i've seen pop up was the gaskets. it sucks there are so many things it could be. i don't have the time/money to be throwing at things that don't fix it
Old 02-05-2013, 10:45 PM   #6
bighaas79
If its dirty it will give incorrect readings. I would try cleaning it first. 95% of the ones I see with both banks lean is usually dirty maf or vacuum leak.
Old 02-06-2013, 12:01 PM   #7
blackbeaSSt
cool. i'll look into doing that. anything recommended/not recommended to clean it with?
Old 02-06-2013, 05:27 PM   #8
thomas_a_reed
thomas_a_reed's Avatar
Had the same problem on my 03 sierra. Changed the intake gaskets cleanend the throttle body, and it runs good as new..
66 CHEVY STEPSIDE 2WD W/283 ( FAMILY HAND ME DOWN)
81 CHEVY SHORT BED 2WD W/250 4SPD TRANS STRAIGHT 6 ( CURRENTLY UNDER CONSTRUCTION)
01 SILVERADO SHORT BED 2WD W/4.3 5SPD TRANS ( DAILY DRIVER) Sold
03 SIERRA 4X4 STEP SIDE EXTRA CAB 5.3 AUTO( NEW DD)
09 CHEVY COBALT W2.2 AUTO (GF'S DAILY DRIVER)
thomas_a_reed is offline   Reply With Quote
Old 02-06-2013, 07:43 PM   #9
m455sx
m455sx's Avatar
Advance auto sell MAF cleaner made by CDC..... thats what i did
1970 442 convertible
1970 Cutlass SX
1962 Chevy Stepside
2011 GMC 3500HD Crewcab SLT DRW
m455sx is offline   Reply With Quote
Old 02-06-2013, 10:31 PM   #10
gmclowsierra
Change the fuel filter.
gmclowsierra is offline   Reply With Quote
Old 02-17-2013, 12:41 AM   #11
sleepertruck72
sleepertruck72's Avatar
I had a truck at work with the exact same codes... I found a vacuum leak at the intake .. used brake clean to find the vacuum leak.. customer didnt approve the intake gaskets but I had snugged down the bolts and it really helped ... but that was just a band aid ... yours may be different ... another truck with the same codes had a tear after the MAF sensor before the throttle body... sometimes theyre easy sometimes not so easy
72 C20 Longbed
05 1500 Z71
sleepertruck72 is offline   Reply With Quote
