Old 02-12-2013, 12:47 PM   #1
Harney Boy
Harney Boy's Avatar
Shaved door handles free?
I've been surfin around forums and i've been wanting to shave my door handles but i dont wanna spend all the money on the electric kits, and i hate wires, dead batteries fires and being stranded more than anything. If i had a complete mechanical way to get in, id be happy.
So, with that being said, does anybody have a good way to open the door mechanically? So far, i like the idea of leaving the key lock on the outside of the door and just using the key to get in, and leaving the inside door handle. The key shouldnt break because all kinds of cars use a key to open the trunk.
But now, is there a good way to make a door "popper" to assist the door to open when i turn the key in the lock? I've heard of a valve spring in the door sill but do i mount it at the back of the door or in the door jam at the front?
Any input is greatly appreciated!
77' 3/4 Shortbed Stepside Silverado
Harney Boy is offline   Reply With Quote
Old 02-12-2013, 01:19 PM   #2
king-918
king-918's Avatar
Re: Shaved door handles free?
I'm sorry but I have to admit I read the first paragraph but I can tell you that all you have to do is run the line under the fender or under the door and mechanically open the door and you'll be fine
<----Christopher
Oh yeah I'm really a Toyota guy, but had some stuff sitting around.
Oklahoma
king-918 is offline   Reply With Quote
Old 02-12-2013, 01:29 PM   #3
Harney Boy
Harney Boy's Avatar
But that means just anybody could open my door, i like the security of needing my keys to open the door. I live in FL so there's plenty of yoohoos looking for a free ride. Lol.
Old 02-12-2013, 01:31 PM   #4
MadManAndrew
There are a lot of ways. Besides your idea, you could run a cable (like a bicycle brake cable, etc.) through the door jam and to another part of the truck for a manual release. I don't exactly know what it would like if you removed the handle but left the lock...
1955 Chevy 3600 http://67-72chevytrucks.com/vboard/s...61#post8589061
MadManAndrew is offline   Reply With Quote
Old 02-12-2013, 01:45 PM   #5
Harney Boy
Harney Boy's Avatar
Yeah a fairly long clutch cable for a dirtbike i could try out. Ill have to decide which way to do it, but does anybody know where to mount the valve spring to push the door open?
Old 02-12-2013, 07:31 PM   #6
rusty76
rusty76's Avatar
Something like a door poper? I think these are spring loaded.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 02-12-2013, 07:37 PM   #7
Harney Boy
Harney Boy's Avatar
I think i can make my own popper with a valve spring, a and a flat washer with a bolt trough it, i just dont know where i should mount it.. yet. Lol
Old 02-12-2013, 08:09 PM   #8
bdiamond
I had a setup that integrated the factory lock into the opener. It was all mechanical. I didn't do it myself, but it was a small S-shaped rod that connected the lock arm to the opener. I think i saw something similar on indestructables the other day. I'll try to find it....
bdiamond is offline   Reply With Quote
Old 02-12-2013, 09:05 PM   #9
Harney Boy
Harney Boy's Avatar
If you could find that id appreciate it a ton! I got home from work and grabbed a shop light and started turning the key lock and the door handle to figure out what i need. A S shaped rod sounds about right.
Old 02-12-2013, 09:41 PM   #10
S10Fan
Old Heap Driver
I know you're looking for cheap, but for $230.00 you can get a complete kit from AVS, latches, remotes, everything.
http://www.avsontheweb.com/product.p...cat=527&page=1
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'30 Model A Pickup, suicide front end, 350, 350, traditional style hot rod.
S10Fan is offline   Reply With Quote
Old 02-13-2013, 02:01 AM   #11
andrewmp6
The really old way is use a cable hidden in a fender well or under the body.Something like a hood cable or e brake cable should be long enough just depends where you want to mount the pull end.
andrewmp6 is offline   Reply With Quote
Old 02-13-2013, 02:29 AM   #12
cory d
cory d's Avatar
maybe something under the bed rail. close to the door and hidden
cory d is offline   Reply With Quote
Old 02-13-2013, 06:05 PM   #13
chet
the pull cable usually runs through the door jamb and intot he door. Thats why under the rocker or in the front fender was most common. My pops old sled had one in the fender. No key locks or electrics. Pretty sure the door popper was a small 4 stroke valve spring with a rubber bumper on the end. mounted in the back of the door by the latch
chet is offline   Reply With Quote
Old 02-14-2013, 09:43 AM   #14
jitteryguy
GoatLube Experss
jitteryguy's Avatar
I did the lock method to a '65 mustang years ago, it work'd fine for several years for me.
as far as the cheap pop'r look in the junk yard's, alot cars had small pop'rs. I dont think you'll need mine never had one
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
door, shaved
