02-21-2013, 01:06 AM | #1 |
2000 chevy unknown driveline noise?? help
ok my daily driver is a 2000 chevy 1500 ext cab Z71 4x4 with 180k on the odometer. in the past few days i have noticed a new noise while driving. thinking it was a bad u-joint i changed all the u-joints yet it still exists. i had the 4l60 rebuilt about 5k miles ago by a reputable shop. the noise isnt followed by a vibration that i can notice but i cant pin point it as it seems to echo thru the aluminum driveshaft. i cant tell if it is coming from the t-case or the rear end? while coasting you can hear it but under power it gets louder? the rear wheels seem to be fine bearing wise?? but i am lost as far as my next move. time and $$ shortage are an issue so any help would be greatly appreciated so i can resolve this myself.
thanx BBB |
02-24-2013, 08:06 AM | #2 |
Re: 2000 chevy unknown driveline noise?? help
I have the same truck (2000)except 2wd and I recently started hearing a similar if not the same noise.
2000 Chevy 1500 Ext. cab |
02-24-2013, 09:10 AM | #3 |
laying low
You fellas may be able to put your trucks on a lift and with it running get up under it and maybe narrow it down.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
02-24-2013, 09:38 AM | #4 |
It sounds like a pinion bearing to me in the rear end. Try driving at a steady speed and manually downshifting the trans to get some engine breaking. Does it make the noise then too?
Posted via Mobile Device |
02-24-2013, 10:49 PM | #5 |
you sir are correct! it is the pinion bearing starting to go out. i had my mechanic look at it this weekend. thanks for your help fellas!
03-02-2013, 10:52 AM | #6 | ||
