Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 02-24-2013, 05:10 PM   #1
Todd68Chevy
Todd68Chevy's Avatar
Will a 1994 and up bed fit on a 1993 frame
I know it will fit with modification but I want to know if it will fit without modification to the frame or bed. I know this is a odd question but I am putting a 1993 S10 frame under my 1946 truck cab. I need a bed floor and want to go with the stock S10 style bed floor in my 46 style bed like the guy did here http://www.killbillet.com/showthread.php?t=16296&page=2 I have not cut any of the original bed mounts off of the frame yet and thought that if I went with a 93 and older bed it should bolt right up. Since they are older, beat up and rusty, I thought I would check on the newer style beds. I know several things are the same with the frames between the years so I thought maybe I could luck out and the rear frames and bed mounts would be also. If someone has pictures of the rear frame of a 94-up S10 and can post them or give me the link to where to find them, I might be able to just compare. Thanks for any help or advise.
Note: All parts I have for sale are also for sale locally.
I currently own: 1940 Chevy Fire truck (project), 1946 Chevy truck (project), 1946 Chevy 1 Ton pick up, 1953 Chevy school bus (storage area), 1968 Chevy C10 (I have drove for 26 years), 1994 Chevy C2500 (daily driver), 2005 GMC crew cab K2500 (parts hauler) and more trucks for parts.
Todd68Chevy is offline   Reply With Quote
Old 02-24-2013, 06:47 PM   #2
BarryB
BarryB's Avatar
Re: Will a 1994 and up bed fit on a 1993 frame
I don't see why it wouldn't, since everything else on the frames are pretty much interchangeable. I don't have any pics or links for the info you need. Maybe check out some other S10 forums
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 02-25-2013, 12:45 PM   #3
98layinframe
98layinframe's Avatar
Yes it will bolt right up no problem.
91 s10 - bagged bodydropped 4", 350/700R4, narrowed reared, cantilever rear air bag setup
1951 chevy 3100 - in build/acquiring parts process. Have full C4 Corvette suspension front and rear, tpi 350, 700r4, 18" torque thrust II wheels
98layinframe is offline   Reply With Quote
Old 02-25-2013, 06:51 PM   #4
Todd68Chevy
Great to hear. Thanks
What I am wanting to do is post 5 & 6 in this thread http://67-72chevytrucks.com/vboard/s...d.php?t=454644 but since I am using an S10 frame and still have the original frame mounts, I want one that bolts up and fills my bed. Here is another one http://www.killbillet.com/showthread.php?t=16296&page=2
Thanks again
