02-25-2013, 12:14 AM | #1 |
66 C10 Rally Wheels
I just purchased a 66 C10 and it has the rally wheels you see below. 15x8 up front and 15x10. These are 6 lug and im getting ready to convert to 5 lug. Does anyone know what these came off originally? I will selling these as soon as i convert over. Going to install 81 front cross member and replace the axles.
Thanks for your help |
02-25-2013, 12:55 AM | #2 |
Re: 66 C10 Rally Wheels
Welcome to the forum!
if they are 6 lug, then they are likely aftermarket. They are made to look like corvette or camaro rally wheels, but in a 6 lug pattern. They are not truck rallies. If you LIKE the wheels, there's no real reason to convert to 5 lug as you can get a db swap that uses 6 lugs. If you're going to change wheels anyway, then all bets are off, a 5 lug swap will give you many more car wheel options. |
02-25-2013, 01:01 AM | #3 |
I kind of thought they might be aftermarket wheels. I have the 81 that im going to use the front cross member from to get disc powerbrakes and going to machine the 81 axles to convert the rear to 5 lug. Thanks for the replay
02-25-2013, 01:17 AM | #4 |
60-66 Nut
As jocko said, those are aftermarket wheels.
02-25-2013, 08:29 AM | #5 |
looks like Wheel Vintiqes aftermarket.
