Old 02-26-2013, 07:53 PM   #1
Jdubs71
Jdubs71's Avatar
Harness for LSx swap
I have two DBW harness's. one is uncut and the other was cut when the motor was pulled. Will throw them both into one box $150 + shipping. This is also for sale locally.
71 K5, AC/Tilt, 4" lift 33" tires
5.3L/4L60E/NP 205 (Under Construction)
05 Dodge 2500 4x4 5.9 Cummins (Daily driver)
"Common sense is not so common"
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=555879
Jdubs71 is offline   Reply With Quote
Old 02-27-2013, 12:24 PM   #2
ChevyCruizer
17's too small
ChevyCruizer's Avatar
Re: Harness for LSx swap
So there are factory drive by wire harness? Where was the cut one severed? Any pictures? How much of the harness is there? What year harness, did they have active cylinder management, etc...
Thanks, John
68 C10 SWB SS 5 lug power disc brake conversion 2.5 inch drop spindles van tilt column Air Ride Technologies Cool Ride air bag kits Performance Online tubular upper control arms and shock relocator kits ECE super track panhard bar 1 piece side windows
ChevyCruizer is offline   Reply With Quote
Old 02-27-2013, 12:57 PM   #3
Jdubs71
Jdubs71's Avatar
I do know this harness has the blue/green connecters to the ecm for the later model vortecs. I believe GM came out with the active fuel management in 2002 for some trucks, but the lsx guys will know more about that stuff. I actually have two harness's the cut one was cut at the ecm connecters. The other is un cut as far as I can tell. I will get some pics up tomorrow.
My build thread
Old 02-27-2013, 01:27 PM   #4
Jon01
Jon01's Avatar
No AFM until 05 and then it was only on Trailblazers/Envoys with the aluminum LH6.
Good price if they're pretty complete.
Jon01 is offline   Reply With Quote
Old 02-27-2013, 01:34 PM   #5
Jdubs71
Jdubs71's Avatar
Thanks I wasn't sure when afm came out.
My build thread
Old 03-01-2013, 03:50 AM   #6
Jdubs71
Jdubs71's Avatar
Here are some pics of the two harnesses. I forgot to mention these still need to be re-worked for your application or could be used as a direct replacement for your sock harness.
My build thread
Old 03-16-2013, 07:34 PM   #7
Jdubs71
Jdubs71's Avatar
Ttt
My build thread
Old 04-23-2013, 10:14 PM   #8
Jdubs71
Jdubs71's Avatar
My build thread
Old 04-23-2013, 10:15 PM   #9
Jdubs71
Jdubs71's Avatar
Bump for a new price $150 shipped
My build thread
Old 05-16-2013, 10:36 PM   #10
Jdubs71
Jdubs71's Avatar
Ttt
My build thread
