Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 03-11-2013, 01:10 PM   #1
earl84
2000 single cab harsh ride softening suggestions?
I bought my daughter a 2000 S10 LS a couple years ago. Had to put a new engine in it, and she really likes it. BUT, DAAAYUM, I hate the ride of that thing! I feel every bump and dip in the road. Seems like the shocks are doing their job just fine, as it doesn't bounce around.
I know with some weight in the back it would probably be better. She will rarely, if ever have more than 50 pounds back there, and will never tow anything. Is there some way of softening the ride? New springs with a softer rate, new shocks, pulling a spring out of the spring pack, anything? And are there effects of doing these that need to be compensated for, like if I pull a spring, will it need the front lowered or whatever?
She is moving from Texas to PA in May. It doesn't bother her, so maybe I should just let her keep it that way and stop thinking about it, haha.
earl84 is offline   Reply With Quote
Old 03-11-2013, 01:21 PM   #2
Billett
Billett's Avatar
Re: 2000 single cab harsh ride softening suggestions?
The one I bought was lowered by the PO on cut springs and drop blocks. It rode like hell, but many of the other s10s I rode in weren't much better. Bagged trucks weren't bad, but that's a bit expensive. Is this truck lowered already?
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
Old 03-11-2013, 01:38 PM   #3
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
I don't drive a truck. I drive a Jimmy. It's heavier than a truck. I solve a control and stability problem by going to larger tires. More tire = more rubber = smoother ride. Due to the larger tires, I also run air pressure on the lower side. If I inflate to the upper end, I feel every bump and crack.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 03-11-2013, 02:15 PM   #4
earl84
No, stock everything. Stock tire size, rim, ride height, suspension, everything. Could maybe check tire pressure, but don't know if that will take care of this harshness. Can't hurt though.
Old 03-14-2013, 07:09 AM   #5
midniteblues
midniteblues's Avatar
the ride might not bother her down there in texas but up here in pa our roads are TERRIBLE!
every s10 i've had or been in feel like a washboard i'm guessing its just the nature of a small truck.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 03-15-2013, 07:44 PM   #6
BlackedOut67shorty
BlackedOut67shorty's Avatar
By any chance would it be a zr2? They came with stiffer shocks from the factory. Some used bilstiens even not being zr2 but was not too common
1995 s10 blazer 4.3
1967 c10 350/350 fleet short
1993 s10 blazer 4.3l 4l60 RIP 6/20/14
2000 mercury sable
Thats a how I roll
BlackedOut67shorty is offline   Reply With Quote
Old 03-16-2013, 12:33 AM   #7
earl84
Nope, not a ZR2.
Old 03-16-2013, 01:16 PM   #8
BlackedOut67shorty
Well its better than being loose and sloppy
1995 s10 blazer 4.3
2000 mercury sable
Thats a how I roll
Old 04-11-2013, 12:53 PM   #9
98layinframe
98layinframe's Avatar
Is it a v6 or 4 cylinder truck? Out back you can simply pull the middle leaf from the pack to soften the ride but this will also end up lowering the truck about a 1.5"
Up front if itsa v6 you can swap out the springs for 4 banger springs. This also will lower it approx 3/4-1"
For shocks the cheapo nitrogen charged gas shocks work well. I had stiff belltech drop shocks on mine and hated the buck board ride, swapped them out for cheap part store 15 dollar specials and it rode much softer.
91 s10 - bagged bodydropped 4", 350/700R4, narrowed reared, cantilever rear air bag setup
1951 chevy 3100 - in build/acquiring parts process. Have full C4 Corvette suspension front and rear, tpi 350, 700r4, 18" torque thrust II wheels
98layinframe is offline   Reply With Quote
Old 04-12-2013, 08:53 PM   #10
earl84
It's a 4 cylinder. Good suggestions, but I don't know if I will get around to doing anything to this truck. It's my daughter's, she is 19 and she has moved away, so I no longer have access to it. Maybe that's good, I can concentrate on my own vehicles.
Old 05-26-2013, 07:46 PM   #11
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
You've obviously never been to Tx.There are two kinds of roads there,closed and under construction.The closed ones are usually smoother.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 05-28-2013, 03:22 AM   #12
76C10Stepside
76C10Stepside's Avatar
Somebody recommended velvet-ride shackles in regards to a 1-ton (?) the other day. They are basically two-piece shackles that swivel in the middle.
My '89 S10 rides smoother than my '76 C10 when both are unloaded. The S10 has the optional sport suspension package (not sure what's in that other than sway bars). I put drop shackles on the C10. Have been wondering if I could add the original shackles to the drop shackles to make my own "velvit ryde" shackles, probably be way too long, though. I'm already bottoming out against the bed...
76C10Stepside is offline   Reply With Quote
