03-12-2013, 10:38 AM | #1 |
Old member
Garage Storage
I want to add some storage over the truck and Tahoe in the garage. Want to put coolers and light stuff up over them on some kind of shelf. What has everyone done and draw backs if any have you encountered since doing it.
Between the Bud clock and the wall on both sides. The right side will have the Tahoe park under it so it will have to be short.
03-12-2013, 05:41 PM | #2 |
meowMEOWmeowMEOW
Re: Garage Storage
I've seen old painters scaffold re-used for a simple "just toss it up there" space. Holds a fair amount of weight.
If you make anything large enough to actually walk in-on....be careful of your homeowners insurance. I know that they aren't friendly about "improvised"....anything. Sounds dumb but a friends dad built a "man-shelter". A dang near bomb proof building with a second "loft" space for an office and storage. They made him install a 3ft railing due to some such thing about un-protected ledges over 16ft.
03-12-2013, 06:02 PM | #3 |
Re: Garage Storage
You can see where the studs are so you can punch a hole in the ceiling or use some heavy duty L-brackets to attach some 2x4s to the ceiling joints. Bring them down as low as you want them, then connect everything together on the bottom, throw up some plywood and you have shelves.
http://www.familyhandyman.com/DIY-Pr...tions/View-All
Willie Swamp Angel Truckers '72 C10 Highlander People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. |
03-13-2013, 07:51 AM | #4 |
Re: Garage Storage
I only lost 3.75" of room! For bigger items I would say frame up a shelf and put up as high as you can and attach to wall and ceiling. I don't have my shelves done yet.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
03-16-2013, 11:31 AM | #5 |
Re: Garage Storage
there's a fellow around here that has a awesome 70 camaro with the driverside roof all bashed up. he said one day somebody slammed the door to the garage and a shelf above the car with gallon paint cans fell on the car he claims he never saw it coming/happening whatever you do if its above your rides MAKE IT STURDY and SECURE.
my problem is during the winter when my car is packed away I seem too allways need something thats above the car and very hard too get too
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
03-16-2013, 12:37 PM | #6 |
Re: Garage Storage
i'd focus on making better storage on the walls
with over head storage all i can think of is how much your head is going to hurt when you run into it
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
03-21-2013, 10:51 AM | #7 |
78K & 79C Jimmys
Re: Garage Storage
I went with side/wall shelves
may have to ask but.....some hardware stores will sell rougher/dirt/sundamaged/wet marked plywood 1/2 the price(or less) of "nice" stuff I got 4X8 sheets cut in half so 2X8 screwed 2x4 along the front/back edge measured out the height size of the storage "buckets" screwed the legs to shelves I can take some pics.... makeing a work bench this spring
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
03-21-2013, 12:12 PM | #8 |
Re: Garage Storage
I have most of my sheetmetal eqpt down the one side of the paint booth. This left the top part of the booth wall as un-used / wasted space. I got cabinets to hang on the booth for additional storage....
...and custom-tailor the inside as needed...
Robert |
03-21-2013, 02:39 PM | #9 |
Re: Garage Storage
I have these hanging from the ceiling: http://www.hyloft.com/ceiling-storage/
I have 2 of the 48x48 units. Got them at Lowes.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
03-24-2013, 08:41 PM | #10 |
I am a Referee of life.
Re: Garage Storage
Go to "Restore",buy upper kitchen cabinets and hang them on the wall High enough to get under with the Ho'Then use the area inside to store stuff and put more on top.The doors will keep stuff cleaner and out of sight(looks less cluttered).You might also find a Kitchen remodeler who would sell you "take outs' resonable.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
05-19-2013, 01:09 PM | #11 |
Re: Garage Storage
I have an issue with storage space in my garage...it's an unfinished garage,no drywall or insulation between studs,etc. (that may be a project in the future).I'm interested in using the open space above the beams,up to the rafters,for storing spare parts and general "stuff"..However,with the existing beams I estimate that I have apprx 10 ft. of ceiling height when I do drywall it.What I'm wondering is,what are your opinions as to what works best in terms of needing overhead space for working on our trucks?..I'm thinking here for a hoist when pulling an engine..? I'm asking this because I'm considering doing something like adding overhead shelves similar to the picture in kcsa 75's post.
_____________________________________________ 69 C-20 292, 4 spd O/D, 4:56 rears. No a/c p/s p/b p/w......restoration project,"Operation:Stovebolt" 78 C-10 305 TH350 new (old) daily driver 02 Suburban Z71 a.k.a. the family truckster 99 Silverado 1500 Z71 |
05-20-2013, 08:08 AM | #12 | |
Re: Garage Storage
I would try to save that space for over the truck for like you said pulling a motor with a overhead hoist or even adding a lift someday so you can lift the truck to make it easy to work on. In my workshop I put wood across the bottom of the overhead joist (rafters in my case) perpendicular to the joist and slide in long pieces of pipe, broom handles, molding pieces, whatever would fit in between the joist. I'm a remodeling contractor so I have all kinds of oddball things.
Toys/projects Many toys, not enough time to play! My youngest son and I picked up a 69 Chevy C-10 on 1/7/22, this is my second 69, it was 10 years ago that I had my other one. So I’m back!!! |
05-20-2013, 05:46 PM | #13 |
Re: Garage Storage - Ditch the Peg Board - Go wtih Cleat System
I have an interesting shop tool organization system that you may be interested in...
I've been working to try to get my garaged organized for some time now.. and still not even close. I have a small, one and half car workshop, and was jumping from one project to another and things got out of control! So, I decided to start with the organization of my tools. I was looking for a system that allowed me to utilize my entire wall space above my bench, because all the other walls are taken… hanging shelves, floor shelves, compressor, table saw, band saw, etc. Cluttered Bench and Peg Board Like most of you, I had one small piece of peg board with tools hanging among. Tools were accessible, but no organization and clearly not enough room for all my tools! On any one project, I would have to go to two, three or more places for the tools in need… I would dig through my toolbox, look on shelves, de-box items for that’s how I stored them… then retrace my steps to put everything back (well sometimes). That’s when things went sour, when I didn’t get things back! I had tools everywhere, couldn’t find what I needed, and clutter all over my bench! Maybe some of you can relate! Then I found this system... it's called a French Cleat (some call it a closet cleat from closet organizers)!! Ever seen it? From all my web searches, its mostly used in the Woodworking community, more so than shade-tree mechanics. It’s actually a very simple, very ingenious design, and yet, very, very strong! It’s basically two mating pieces of wood that are cut at 45°. This “wedge” is the premise of the system... it works based on gravity and back-pressure! I simply took a 1x4, and with a 45° cut, ripped the board into two long pieces.. one around 2 ½“ (long-side) and the other 1” (short-side). This actually creates both pieces of the French cleat system that you’ll need, all from one board. You need to mount the wider piece securely to the wall studs (with the 45 angled down and into the wall), and the other smaller section is what you use to hang your “Hangers” (Whatever you want to call them… shelves, hangers, boxes, wall cabinets, organizers, parts bins, etc.). Mounting Bottom Cleats to Wall Studs Here is the BEST PART…. Everything is fully movable! They are not fixed to the wall-side cleat in any way, they just simply sit into the wedge and hang, and you can rearrange your “Hangers” anywhere you want! You can match your workflow, by project, or by tool grouping. I have my “most used” tools closer at hand and to my bench… and my least use tools higher on the wall, still accessible, but not taking up prime real estate . New Wall Organization - Cleat System The fun begins by being creative with your ”Hangers”. There are endless possibilities.. I grouped my tools together so everything is together.. drill and drill bits, grinder and discs, you get the idea. Here are some samples of my “Hangers” which have all been built with scrap lumber sitting in my shop…
Search the internet… you’ll find some very clever tool holder designs…. It’s not that expensive to do… I did my entire wall with 1x4s separated 3 ½" for a total of 8 rows, all under $70 including mounting screws. Feel free to share your garage organization techniques… or any comments to the French Cleat System. |
05-21-2013, 07:41 AM | #14 |
Re: Garage Storage
Excellent!! I love it!
I use that same french cleat system for fireplace mantel shelves I make. I can't use it in my current shop, as I have almost all open stud walls, so I just put blocking in between and made shelves that way. I will have to take some pictures of mine.
05-25-2013, 09:55 PM | #15 | |
Re: Garage Storage
I will probably keep one area of shelving for hardware,paint cans,motor oil, coolant,WD-40,sandpaper,dropcloths,..that kinda stuff.I just need to condense the items to be stored on shelves,and confine it all to a smaller area.As far as head room for working on vehicles goes,I was thinking a minimum of 8 ft.,but I don't know if some of you have managed with even less than that. Oh yeah, and there are a lot of cool ideas posted for storage ideas. Everyone has their own system of what works for them,I guess.
05-26-2013, 10:21 AM | #16 |
Re: Garage Storage
How close is your garage door to the ceiling when open? This is wasted space available for storage. We have a canoe that has been stored in a car trailer, and to make it more accessible, and easier to load on top of the wife's SUV, it will get stored here, above the door tracks....
Most of what I found online in canoe hoists looked "lightly" made at best. Plus, I needed to take the ropes to a side wall for securing, which meant no "kit" was complete for what I wanted. I checked a couple different local stores today, and about the cheapest pulleys I could find (with bearings) were ones designed for patio doors. Here they are installed in the 16 ga Stainless brackets I bent up.... Using one for each end, then changing direction mid-stream to take the rope over to the side wall, using this bracket.... Next, I'll make the ceiling to wall transition bracket, and the pulley/hook brackets to support the ends of the canoe. The ceiling to wall transition was made in 3 pieces and fusion welded together.. Then to make the pulley hooks for the canoe straps... Installed, and using a crossbrace from the scaffolding for a dry test run... All the bits installed....
Robert |
05-26-2013, 07:29 PM | #17 |
Re: Garage Storage
Here's the canoe in it's place....well above the door.
Robert |
12-19-2013, 04:02 PM | #18 |
Re: Garage Storage
good ideas here
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
