Old 03-27-2013, 09:39 PM   #1
Low_Life86
Low_Life86's Avatar
Leaf Spring/flip kit problems
i am putting in my flip kit and i replaced my leaf springs in the process. when i went to put my new leaf springs in i realized my shackles were pushed back a bit. and now my leafs look as if they are too short. i got one side in with a lot of struggling and busted knuckles. i have attached to pics to show what i mean is there an easier way to pry the shackles forward at all??
Jeremy
'86 GMC 1500 dropped 6" in the front and 6" in the rear
2003 Land Rover Discovery
Low Life
Low_Life86 is offline   Reply With Quote
Old 03-27-2013, 09:51 PM   #2
J Knight
J Knight's Avatar
Re: Leaf Spring/flip kit problems
Loosen the lower shackle bolt.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 03-27-2013, 09:57 PM   #3
Low_Life86
Low_Life86's Avatar
for some reason these bolts are unbelievably tight and without access to torches at the moment i cant loosen them. they move though with a crow bar they pivot but then instantly snap back into place
Jeremy
Low Life
Old 03-27-2013, 10:02 PM   #4
J Knight
J Knight's Avatar
Then I guess you will need a helper to hold the pry bar while you set the front of the spring.
John
Old 03-27-2013, 10:04 PM   #5
Low_Life86
Low_Life86's Avatar
Then I guess you will need a helper to hold the pry bar.
even with the bar pried all the way down its still off the hole by like 3/4 inch
Jeremy
Low Life
Old 03-27-2013, 10:05 PM   #6
J Knight
J Knight's Avatar
Are those springs 52in long?
John
Old 03-27-2013, 10:07 PM   #7
Low_Life86
Low_Life86's Avatar
48" i think which is the same as what came off
Jeremy
Low Life
Old 03-27-2013, 10:15 PM   #8
J Knight
J Knight's Avatar
As far as I know 1/2 ton trucks only had two different spring lengths, 52in and 56in. 48in sounds way to short.
John
Old 03-27-2013, 10:19 PM   #9
Low_Life86
Low_Life86's Avatar
ya i dont know thats what came off so thats what i was putting back on i dont know
Jeremy
Low Life
Old 03-27-2013, 10:32 PM   #10
Low_Life86
Low_Life86's Avatar
sorry my bad i just checked and i was wrong they were 52 inch idk where i got 48 from
Jeremy
Low Life
Old 03-27-2013, 10:37 PM   #11
J Knight
J Knight's Avatar
So the new ones are 52?
John
Old 03-27-2013, 10:38 PM   #12
Low_Life86
Low_Life86's Avatar
yes the new ones are 52
Jeremy
Low Life
Old 03-27-2013, 10:52 PM   #13
J Knight
J Knight's Avatar
Your just going to HAVE to get the shackle off or loose to install the new spring.
John
Old 03-27-2013, 11:00 PM   #14
Low_Life86
Low_Life86's Avatar
ya i suppose thats my only choice at this point
Jeremy
Low Life
Old 03-28-2013, 08:06 AM   #15
bdiamond
Were those springs used when you got them? The top leaf looks bent.
bdiamond is offline   Reply With Quote
Old 03-28-2013, 09:13 AM   #16
Low_Life86
Low_Life86's Avatar
I don't think they were used just sitting on the shelf for a while. And I don't think they are bent I think it just the picture
Jeremy
Low Life
flip kit, leaf spring, problems, spring
