Old 03-29-2013, 04:26 AM   #1
v30crewcab
v30crewcab's Avatar
vent window gaskets?
So I need new vent window gaskets, are the ones from Classic parts good, or should I spend an extra 20 and get the ones from precision? anyone had experience with the two?
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 04-09-2013, 01:49 AM   #2
JellyBeanDriver
Re: vent window gaskets?
Did you purchase your vent seal?
I've got a vent window on our 86' C30 dually that I need to fix. Leaks air like crazy at highway speeds.
JellyBeanDriver is offline   Reply With Quote
Old 04-09-2013, 01:53 AM   #3
1985_C10
1985_C10's Avatar
my vent windows leak air at about 30. lol. theres nothing left of my seals. i need new rubber all around.
1985_C10 is offline   Reply With Quote
Old 04-09-2013, 08:37 AM   #4
crazeetxn
crazeetxn's Avatar
I ordered the ones from LMC for my 86. Need to replace them though on account I didn't install them right the first time. Apparently, the newer ones have two flaps at the bottom, and they don't BOTH go inside the door
They were thicker and seemed more durable. Not sure about the ones you're looking at though.
1st - '68 long bed
2nd - '81 SWB
Now - '86 SWB, Edelbrock 1406/stock 350/700r4
crazeetxn is offline   Reply With Quote
Old 04-09-2013, 04:14 PM   #5
BVANT1
I ordered mine from the truck shop in Orange California which were Precision. I found a video on Precisions youtube channel that shows some good tips to make the installation pretty easy. Not sure how the vents are on the 81-87's but this is the video for the 73-80. Hope this helps.
BVANT1 is offline   Reply With Quote
Old 04-11-2013, 11:15 AM   #6
Precision Parts
Tech Help
Precision Parts's Avatar
Thanks for posting the video BVANT1. Something to remember on the 81-87 is the difference between 2 piece and one piece design. They are not interchangeable and is one of the most frustrating things I hear from customers.
The two piece design was typically 81-85 and the one piece was 85-87. However I've seen differences in this also. The best way to check is to pull back the division bar glassrun. If you see fold over metal tabs, that will be the two piece design.
Let me know if I can help any further.
Derek
PRECISION
Updates
Subscribe --->Installation Videos
Follow ------->Instagram
Like---------->Facebook
Precision Parts is offline   Reply With Quote
Old 04-11-2013, 12:29 PM   #7
Greenlee
Greenlee's Avatar
Definitely check what type you need before you buy! I bought the one piece seals for vent windows that came out of a 1989 Suburban and it turned out to have the 2 piece design. I wasted a lot of time trying to rebuild my vent window before I figured out the seals wouldn't work.
Greenlee is offline   Reply With Quote
