Old 03-31-2013, 10:51 PM   #1
Russ.W.
Russ.W.'s Avatar
Question Trying to ID a steering box.
G'day all. I have a manual steering box from my factory '67 right-hand drive C10, and am trying to find out what else it came on. Google doesn't seem to give me much.
I'd like to eventually upgrade to power steering, but need to know what other vehicles this box came on, so I know where to look for a proper fitting power steering option.
Part # is 5673800
Thanks for your time.
Old 04-01-2013, 12:15 AM   #2
airdale94
airdale94's Avatar
Re: Trying to ID a steering box.
On the left hand drive the 73-87 can be adapted if you get the steering linkages. So what I would do is try looking for interchange for those. Then just look for vehicles of that type that are right hand drive. Sorry if my explanation is not that clear.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member).
airdale94 is offline   Reply With Quote
Old 04-01-2013, 12:37 AM   #3
LSUMurse
LSUMurse's Avatar
I don't know if you want to go this route, but this guy looks like he built a box to be able to mount a LHD gearbox.
http://c10forum.com/forum/showthread.php?t=4395
I guess it's an option.
It's not that I am apathetic, I just don't care.
If your life is a joke, it appears death will be your punchline.
LSUMurse is offline   Reply With Quote
Old 04-01-2013, 01:45 AM   #4
SS Tim
SS Tim's Avatar
Remember reading an PV4 magazine article about a shop converting a new full size late 70's Jeep Wagoneer to RHD (expensive) for export down under. In the conversion they used a Chevy Blazer box mounted inside the right frame rail to mimic the factory LHD that used a box on the inside of the left frame rail. So it stands to reason a FSJ LHD P/S box would be a near bolt in change that would mount to the outside of the right frame rail.
SS Tim is offline   Reply With Quote
Old 04-01-2013, 02:53 AM   #5
Russ.W.
Russ.W.'s Avatar
Thanks for the replies fellas.
Tim, I was thinking the same thing. Find a LHD car which has the steering box mounted to the inside of the frame, and that should work for me on the outside of the right frame.
Problem is the design of the boxes. Whilst the mounting is on the correct side, and the shaft and gear for the pitman are all facing the correct direction - they are on the wrong side of the box.
If you look at my image above, the steering rod is on the outside, and the pitman arm is on the inside closest to the frame. If I was to take a box from a '67 Camaro, the mounting holes are on the correct side, but the steering rod is on the inside whilst the pitman arm would be on the outside. So it won't work.
My RHD box:
67 Camaro box.
Problem with all other boxes I've seen from other manufacturers like Jeep etc, is they're all the same layout as the Camaro. Steering shaft inside, pitman outside - I need them reversed.
Old 04-01-2013, 01:49 PM   #6
Spartan
Spartan's Avatar
Odd. The Jeep factory in Aus. made FSJ until 81 iirc.
'69 K20 350/4 speed/Rockwell/D44/HO52.
"orange rhymes with door hinge"
Spartan is offline   Reply With Quote
Old 04-01-2013, 02:28 PM   #7
SS Tim
SS Tim's Avatar
Pretty sure it was Brian Chuchuas Jeep's speciality shop. Also that it was a loaded Grand Wagoneer that the owner purchased while visiting the states and had it shipped home after being converted. IIRC there was also something like a 100% import duty too. Earlier I was just presenting something I remembered and hoped it would be a workable solution.
But it turns out Russ is right the sector shaft would be on the wrong side for his needs. Did some looking and tried to jog my memory on range Rovers and such that were avaliable as RHD and still haven't found anything "great".
Old 04-01-2013, 07:04 PM   #8
Spartan
Spartan's Avatar
Chucha is one of the guys I always looked up to...still do. He took jeeps to a level few could. I also checked and I was wrong. They got partially built jeeps and converted them in the Brisbane plant. The import duty killed jeeps in Aus. The XJs were considered cars because of the unit body and got the higher tax. Something they got there in good numbers that we didn't see here were the cj-10s.
Maybe look at toyotas? Should be millions of them down there. HiLux?
I know I read about a solution somewhere but my gray matter filing system is broken.
Old 04-01-2013, 11:41 PM   #9
Russ.W.
Russ.W.'s Avatar
A Hilux box will work in theory - everything's in the right place. Just a mtter of mounting and correct placement.
However, I'd really like to know what else this box came from, as I'd much rather use the correct gear. Plus the more info I can get on this car and it's parts, the better.
Unfortunately, the part number may be strictly for RHD pickups, so finding someone with a RHD pickup with factory PS may be my only hope.
The only thing Google brings up is a repair kit for it which includes several other steering box numbers. Unfortunately I can find info on all the other boxes mentioned - except mine (and all of them are also wrong for my C10).
I appreciate everyone's input though. It all helps.
Old 04-02-2013, 11:48 AM   #10
mrolds88
Just saw the post. Interesting. As I was reading, My first thoughts were of the Camaro/ Chevelle type box. Then you pointed out that nasty little thing with the layout. Shoots my idea in the head. I think now I would look a a salvage yard. Obviously I would look at Holden offerings. Maybe if you were lucky you might even run into a later GM pickup with Power steering.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 05-24-2013, 01:23 AM   #11
Russ.W.
Russ.W.'s Avatar
G'day all!
OK, so after a bit more searching; and almost zero discovery, I've come to the conclusion that there is no power steering box replacement.
I've looked at a few South African brochures for the C10, as well as an Australian brochure - and it appears these RHD export trucks were only available with manual steering. There wasn't a power steering option at all, so it's a good guess that GM/Saginaw never actually made a power steering box for these trucks during this era.
I have however given my manual box a clean and discovered a bunch of numbers I didn't even know were there (that's how thick the rust and gunk build up was).
Can anyone shed some light on these numbers? Would love to know what they mean.
Cheers,
Russ
You can click on the first image to get a higher-res if desired.
Old 05-24-2013, 09:54 AM   #12
Katrina/10
Katrina/10's Avatar
Did you look for 73-87 model RHD power gear boxes? I think those would interchange with your manual box. Also, you could use your manual box with the power assist external ram style steering. I think that's what 67s came with anyway.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 05-24-2013, 10:45 AM   #13
Spartan
Spartan's Avatar
Are those A-Arms in the picture of the front end?
Sorry I can't help with numbers.
I would hazard a guess at part numbers?
Cheers
Nim
Old 05-24-2013, 06:50 PM   #14
Russ.W.
Russ.W.'s Avatar
The 73+ model was released here locally, and they were the brochures I was talking about. They didn't offer a power steering option for them. Manual only. Every truck I've seen has had a power steering conversion using parts from everything, cutting into the frames etc. There's no simple bolt-in option.
Old 05-24-2013, 07:06 PM   #15
Katrina/10
Katrina/10's Avatar
Oh, I see you already thought of the 73 and later option, sorry. How about the external setup? Really these trucks steer pretty well without power steering as long as you don't have big or wide front tires.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Old 05-24-2013, 07:32 PM   #16
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
You might look at an American Postal Jeep.They were RHD and probably PS though I'm not sure.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 05-25-2013, 04:21 AM   #17
SS Tim
SS Tim's Avatar
Russ,
Done a lot of checking into everything I can think of as a donor. Pretty much the only thing that looks the most similar is the 800 series Saginaw boxes like I suggested earlier. As you pointed out the sector arm issue is a big one but may be workable. Here is a "go to" site for me on my Camaro steering number questions that may prove helpful if not just interesting reading for you. http://www.pozziracing.com/camaro_steering.htm
The way I see it many cars have offset steering linkage and you may be able to combine factory parts and come up with an acceptable linkage geometry.
An external ram may very well be a solution too and Corvette components would be a good source for you. Here are pictures of the stock 67 pickup setup as a reference for you.
Then of course maybe a R&P swap is going to be the only easy way.
Old 05-25-2013, 06:17 PM   #18
Russ.W.
Russ.W.'s Avatar
Great pics Tim. Thanks.
Ram assist may be my only option. Being a rare truck, I don't won't to chop anything up, and would much prefer the factory geometry. Bummer about being in this part of the world, I can't just run down to the local junkyard and take a gamble. by the time parts get to me, they cost an arm and a leg - then there's always the chance it doesn't work.
I'll stick with what I have for now, and see if I can track down a 67 ram assist setup.
Would still like to know what the numbers on the box's plate mean. I'm assuming they're on date codes etc, but still has me curious.
Thanks again to everyone for their time & help.
Cheers.
Old 05-25-2013, 07:14 PM   #19
SS Tim
SS Tim's Avatar
Find a local second or third generation Corvette specialist. The ram assist ran from 63-82.
Here is a rebuild thread for you to drool or dread over.
http://67-72chevytrucks.com/vboard/s...d.php?t=253657
Corvette stuff for reference only
http://www.corvettemods.com/product....FaN7QgodtHoAdw
http://www.cssbinc.com/corvette-powe...sion-kits.aspx
http://www.cssbinc.com/images/ads/ho...structions.pdf
http://www.cssbinc.com/images/ads/ho...r_for_1963.pdf
Old 05-25-2013, 07:56 PM   #20
Russ.W.
Russ.W.'s Avatar
Wow. Thank you, thank you, thank you!
Looks like I've found a solution. I know a couple Corvette heads down here so may be able to help if there's any parts locally.
Cheers.
rhd, steering box
