Old 04-05-2013, 12:42 PM   #1
bikeman59
Fabricate a custom tranny cross member?
Hey y'all - I'd like to build a custom tranny cross member for the TH350 in my '80 swb, 2 wheel drive. I know I can build it, I'm just not good with design work. Do any of you have a design for one of these for me to work off of or know of a design on the internet that is a good one to use?
My goal is to eliminate the stock cross member so my exhaust can be as even as possible on both sides.
Any help would be great. Thanks guys!
Project: 1980 Chevy SWB
DD: 1999 Chevy Tahoe, lifted on 33"s
Toy: 1996 HD FLSTC, custom by me
bikeman59 is offline   Reply With Quote
Old 04-05-2013, 01:34 PM   #2
i heart square bodys
i heart square bodys's Avatar
Re: Fabricate a custom tranny cross member?
this seemed like a huge pain in the ass to me when i had this idea for the same reason, an "X" pipe might be your best friend if you want to make your exhaust even and its much easier
i heart square bodys is offline   Reply With Quote
Old 04-05-2013, 02:36 PM   #3
BIG DADDYS 84
just finished mine,find a 73-78 c-10 and cross members will work,installed my headers and hand an angle problem,and 78-up are for single exhaust installed the older cross member and all worked good
BIG DADDYS 84 is offline   Reply With Quote
Old 04-05-2013, 04:13 PM   #4
88Jimmy4x4
88Jimmy4x4's Avatar
They sell them for about $80 ready to bolt up
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 04-05-2013, 07:05 PM   #5
68Timber
I know the pieces fit
68Timber's Avatar
Do you have a link? I'm wanting to try a 3" exhaust.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 04-05-2013, 08:00 PM   #6
69GMC910
MOTORHEAD!
69GMC910's Avatar
www.performanceonline.com it says for 60-72, but apparently fits 73-87's.... just have to drill a few holes that don't line up. I'll be installing mine in a couple weeks.
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Performer RPM Air Gap
Hooker 2455's
TCI Turbo 400 Super Street Fighter
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Hoosier 30x10.5 Radial Slick
Full weight long box pickup
Current best- 11.33@117mph
69GMC910 is offline   Reply With Quote
Old 04-05-2013, 08:33 PM   #7
68Timber
68Timber's Avatar
Someone linked this crossmember a week or two ago. Nice price at $65. Thank you sir.
http://www.performanceonline.com/196...N-CROSSMEMBER/
John
74 Honda Z50 build
Old 04-05-2013, 10:20 PM   #8
88Jimmy4x4
88Jimmy4x4's Avatar
thats not it, this one made by Thorebeck Brothers Trans Crossmember
http://*************/crossmembers/63...on-crossmember
>>>>>>>>>>> put thorbros dot com where the asterisks are in address above....sensorS no likey LOL <<<<<<<<
$69.99
here it is mounted on a 1984
1991 GMC Jimmy 4x4
Old 04-06-2013, 07:04 AM   #9
68Timber
68Timber's Avatar
Do you have to set the height?
John
74 Honda Z50 build
Old 04-06-2013, 07:23 AM   #10
88Jimmy4x4
88Jimmy4x4's Avatar
Im not sure, these pics are from a member here baclay9
1991 GMC Jimmy 4x4
Old 04-06-2013, 12:15 PM   #11
bikeman59
Thanks guys - great info.
Old 04-06-2013, 07:36 PM   #12
wraprail
wraprail's Avatar
I used this TransAdapt drop crossmember. The drop allows you have room for your exhaust. That straight crossmember above will be in the way if you want to tuck your exhaust.
Part #6559
wraprail is offline   Reply With Quote
Old 04-06-2013, 09:18 PM   #13
68Timber
68Timber's Avatar
That's the one I remember seeing. Thank you sir.
John
74 Honda Z50 build
Old 04-06-2013, 10:31 PM   #14
88Jimmy4x4
88Jimmy4x4's Avatar
Originally Posted by wraprail View Post
TheThat straight crossmember above will be in the way if you want to tuck your exhaust.
Exhaust mounts over it not under
1991 GMC Jimmy 4x4
Old 04-06-2013, 10:42 PM   #15
KQQL IT
At the body shop.
KQQL IT's Avatar
Early 3/4 ton x member. Notch the center clears 3" dual on my 73
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 04-06-2013, 10:46 PM   #16
KQQL IT
At the body shop.
KQQL IT's Avatar
Old 04-06-2013, 10:46 PM   #17
68Timber
68Timber's Avatar
Ah chit. I bought one this morning, I thought it mounted high in the frame rails.
John
74 Honda Z50 build
Old 04-06-2013, 11:33 PM   #18
INSIDIOUS '86
INSIDIOUS '86's Avatar
Those look like spintech mufflers mmmmmmm
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 04-07-2013, 01:54 AM   #19
wraprail
wraprail's Avatar
Only issue I have with the single tube crossmembers like the straight one and mine too is that they don't tie the top and bottom of the frame together. If you look at KQQL IT's early factory Xmember it is 3 pieces and hits the frame in 4 places. I modified mine to bolt into the bottom and side of the frame. My 2€
Old 04-07-2013, 07:09 AM   #20
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
PM your email address. I have a custom made crossmember. It's made of 2" tube steel. It's made with dual humps for exhaust routing. Works great. The exhaust it tucked up into the underside.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 04-07-2013, 06:00 PM   #21
KQQL IT
At the body shop.
KQQL IT's Avatar
I had only planned on using the bottom piece without the side supports.
When I drooped the t400 onto it the rail rolled in a good bit. So I put them back in.
Old 04-10-2013, 09:48 AM   #22
rs74
rs74's Avatar
Who made your crossmember. I would like to be able to run a x-pipe above the crossmember if possible. Someone post a link to a site that made them for LS conversions but can not remember the site now. Although I think the exhaust ran under the crossmember.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 04-10-2013, 10:04 AM   #23
68Timber
68Timber's Avatar
I bought the one pictured above thinking it mounted high in the frame. I can't use it with my long tube headers. 20% off sale if anyone is interested.
John
74 Honda Z50 build
Old 04-10-2013, 10:07 AM   #24
rs74
rs74's Avatar
Does anyone have this in their truck or have any pics of it installed in one.
Roy
1987 R10 shortie
Old 04-10-2013, 10:29 AM   #25
rs74
rs74's Avatar
Are you talking about the one from trans adapt or thors bros. There is also one from performance online but there is no pic of it.
Roy
1987 R10 shortie
