Old 04-10-2013, 09:53 AM   #1
rs74
rs74's Avatar
Looking for a link.
Here not to long ago someone posted a link to a transmission crossmember that is designed for LS conversions. I can not find the thread it was in. The crossmember is humped up on both sides so you can run both sides of the exhaust under it. I am thinking it was sold in a kit with some other stuff for a LS conversion. Does anyone remember it?
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 04-10-2013, 10:11 AM   #2
rs74
rs74's Avatar
Re: Looking for a link.
I think I found it. brphotrods. com
I thought about trying this out but since it looks like it only bolts in on the bottom flange of the frame I am not going to. I like how you can run the exhaust which is what I am looking for but would rather have it tie in with the frame like the factory crossmember. Instead I might look into the one on performance online's site.
Roy
1987 R10 shortie
Old 04-10-2013, 10:40 AM   #3
Jonboy
Slots go on anything!
You could run the factory crossmember, and use the Dirty Dingo sliding mounts. That allows you to move the engine for and aft, and put it where you want it.
Old 04-10-2013, 10:48 AM   #4
rs74
rs74's Avatar
I guess I should have stated that I am looking for a crossmember like the one above for my 350 trans. I know it was built for LS conversions but was going to call them to see if they made them for the 350 but then seen how it was tied to the frame. No LS conversion here just a 355 and 350 trans.
Roy
1987 R10 shortie
