Old 04-13-2013, 12:16 AM   #1
Tito19
Transfer Case I.D.
So we pulled my dads 69 k20 truck out of the field its been siting in for more than 12 years and started wrench on it and came across this transfer case under the truck. It doesn't look like any of the usual transfer cases on this gen truck(np205,206). As you may have noticed, I'm new to these trucks. Thanks.
Tito19 is offline   Reply With Quote
Old 04-13-2013, 12:39 AM   #2
snj8198
snj8198's Avatar
Re: Transfer Case I.D.
Rockwell 221. Welcometo the board.
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 04-13-2013, 12:45 AM   #3
Tito19
Thank you snj8198.
Old 04-13-2013, 07:06 AM   #4
jjzepplin
jjzepplin's Avatar
Welcome sir! That is a great start to a nice ride. Wonder why he would just leave it in a field? I guess so he could pass it on to you!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 04-13-2013, 07:10 AM   #5
andrewmp6
Yeah its a rockwell t221,Is the truck a stick?
andrewmp6 is offline   Reply With Quote
Old 04-13-2013, 10:34 AM   #6
68panelman
68panelman's Avatar
Special-k "Tim" will like that one.
68panelman is offline   Reply With Quote
Old 04-13-2013, 09:28 PM   #7
Tito19
Didn't have room at the house and didn't want to get rid of it, that was the next best thing. Yea it's stick.
Old 04-14-2013, 10:37 AM   #8
eric67m
eric67m's Avatar
What size tires are on your truck? I assume there is no lift. Do you know if they rub?
I need tires in the future.....
67 K10, lwb, fleetside, 327, 4spd, 205, cab and 3/4 frame swap, 14 bolt, big window, and a "rustoleum roll job"
eric67m is offline   Reply With Quote
Old 04-14-2013, 12:01 PM   #9
Tito19
Tires: 35x12.5x16.5 they did rub so I notched out about ~2.5 inches on fender. The rear fit fine with no rubing. When I say no rubing this means on the street, haven't had the chance to articulate the suspention but it looks like there is room. O, and you are correct no lift.
Old 04-16-2013, 12:22 AM   #10
'63GENIII
'63GENIII's Avatar
Welcome and nice truck. T221's are decent. Make sure it has enough oil at ALL times. They tend to run a little warmer and be a little louder than the 205's but with proper care should fare pretty well
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 04-16-2013, 02:04 AM   #11
Tito19
Thanks for the heads up and welcome. Members seem friendly and knowledgeable, I think I'm going to like it here. ��
k20, transfer case
