Old 04-15-2013, 02:54 PM   #1
mwilliams5891
12 bolt car vs. truck
Ok it's been a really long time since I've been on here....but it's good to be back!!! Anyway I am back working in my C10 and I was getting the parts lined up for the rearend and was reading about the difference in car vs. truck and I don't know what I have....it was given to me not with a rig so I'm worried and I don't quiet understand what is different....is the housing? Or the internals? Or all of it? I was going to replace everything but the housing pretty much....new 5 lug axels and an rayon posi unit with new gears....but I'm scared of buying missmatched parts...I have tried to search on here and the Internet with bono luck so hopefully I didn't miss a lot...but anyway thank for your help!!! You guys are the best if the best
-1969 C/10 Short Step soon to be Brand NEW Ls6/T56
-03 Mazda Protege 5
-WTB 1970 Chevelle project
mwilliams5891 is offline   Reply With Quote
Old 04-15-2013, 05:50 PM   #2
Ziegelsteinfaust
Re: 12 bolt car vs. truck
Nothing interchanges expect maybe a few gaskets, and their gear ratio's are a bit limited by comparison.
They are two different rear ends, and the car is better in nearly every way. If I am not mistaken the 8.5 10 bolt is stronger in more ways too then the truck 12 bolt.
Ziegelsteinfaust is offline   Reply With Quote
Old 04-15-2013, 06:07 PM   #3
Gumby
Gumby's Avatar
Most of the BOP ones are nice for a shell because its 4 link ready, first thing you do to a race car and off road truck, 4 link system. on the cars it just wasn't adjustable with stock arms.
just be careful for the 8.75 10 bolt cover with a 12bolt carrier inside, lots of those are posi [got one] but no one makes parts and no parts from others will fit. [you can reuilb the posi] can't even get the right 10bolt cover gasket, as its bigger then a 10bolt, but strong as a tank.
Gumby is offline   Reply With Quote
Old 04-15-2013, 08:07 PM   #4
clinebarger
1. Chevy car 12 bolt.
2. Truck 12 bolt.
clinebarger is offline   Reply With Quote
Old 04-15-2013, 08:11 PM   #5
clinebarger
The only things that make's the 8.5" & the Car 12-bolt stronger is the larger pinion stem diameter & only seen one break.
Old 04-15-2013, 10:10 PM   #6
Ziegelsteinfaust
I've heard the axles are slightly better, and usually have more teeth. Also the main caps are supposed to be a touch better.
If my truck had one I wouldn't rip it out, and I would actually build it up a bit. There fine for just about anything thrown at them. Except 500+ HP, and sticky tires. Or heavy off-roading.
Old 04-16-2013, 12:39 AM   #7
Captainfab
60-66 Nut
The 12 bolt car and truck both use 30 spline axles. The 12 bolt car gears can actually be used in the truck housing. There is a thread on this forum in the "Racing and High Performance" section with the bearing number to make it work.
There are actually a few members here that race their trucks and are still running the truck 12 bolt.
Old 04-16-2013, 11:46 PM   #8
mwilliams5891
So how do I know what I have? I am assuming the housing are different...so do they measure out different? I'm fine running a truck 12 bolt I just wanna make sure I get the right parts
-03 Mazda Protege 5
Old 04-16-2013, 11:54 PM   #9
clinebarger
The rear covers are shaped different....Did you not see my earlier post?
Old 04-17-2013, 12:04 AM   #10
Captainfab
60-66 Nut
Here is a link to a page with some more info on identifying a car 12 bolt from a truck 12 bolt.
http://www.drivetrainshop.com/GM_12_Bolt_s/105.htm
Old 04-17-2013, 12:42 AM   #11
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
I sold the rearend from my 68 to a guy with a chevelle who was tickled to get it? lol idk
John
1999 Toyota Tacoma 4x4
Old 04-17-2013, 06:44 AM   #12
69trk
69trk's Avatar
I'm running a truck 12 bolt with moser 33 spline axles c-clip eliminators and a car 12 bolt billet yoke and a full spool with welded axle tubes.. Works great so far.
http://67-72chevytrucks.com/vboard/s...d.php?t=494388
431 big block times, changed to a 6.0 ls with turbo
1.58- 60'
7.18- 1/8th mile@95.18
11.37- 1/4 @115.81
69trk is offline   Reply With Quote
Old 04-17-2013, 11:55 AM   #13
mwilliams5891
No I'm sorry It didn't come through thank you!!!! That was exactly what I needed!!!
-03 Mazda Protege 5
Old 04-17-2013, 01:12 PM   #14
JMac11
JMac11's Avatar
Raced a Narrowed 12 bolt with factory posi for years, twisted an axle once, but that was about it. 3500# car 14x32 slicks running 10's It's all in setting them up properly.
JMac11 is offline   Reply With Quote
Old 04-17-2013, 02:07 PM   #15
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Like mentioned earlier... the "weak" link in a truck 12-bolt is the smaller pinion diameter as compared to the car 12-bolt. But I have seen a lot of cats with trucks with truck 12-bolts putting some serious punishment to them, and they hold up fine.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 04-17-2013, 04:24 PM   #16
mwilliams5891
Thank you guys just one last question and I know it's kind of broad but any idea what someone would charge to install the new posi axels exit if I bought parts....just strictly labor I have read the sticky and I might do it myself but just checking
-03 Mazda Protege 5
12 bolt, car, truck
