Old 04-30-2013, 08:26 AM   #1
82ccshorty
82ccshorty's Avatar
Wanting wrecked duramax
Does anyone here know of any wrecked duramax trucks for sale? Wanting to for a conversion. Prefer 150k miles or less and the more parts that's there the better. Thanks
1969 chevy camaro Z28 #matchin Factory 4wheel disc
1969 chevy cst10 big block overdrive 5/7 drop dog dishs
1997 gmc yukon 2 door 2 wheel drive project 4/5.5 22s
2004 gmc sierra dually 4/4 lowering daily driver
82ccshorty is offline   Reply With Quote
Old 04-30-2013, 08:29 AM   #2
82ccshorty
82ccshorty's Avatar
Wanting a wrecked duramax
Anyone's know of any wrecked duramaxs for sale let me know. Wanting one for a conversion. Prefer 150k or less and the more parts still there the better.
Old 04-30-2013, 08:35 AM   #3
truckdude239
truckdude239's Avatar
Re: Wanting wrecked duramax
XIV. Multiple Posting - It is simply not acceptable to post your question more than once, or to post it in more than one forum. Choose the forum that your question or post best fits in, and place it there and only there. If, after posting, you feel it should be in another forum, private message the forum Moderator and ask if they would move it for you.
YOUR THREADS HAVE BEEN MERGED
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 04-30-2013, 10:08 PM   #4
clinebarger
Dealers License!!! & cruise the insurance auctions. Buying a wreak from a Broker will cost you Thousands, What year are you looking at?
clinebarger is offline   Reply With Quote
Old 05-01-2013, 08:22 AM   #5
82ccshorty
82ccshorty's Avatar
I don't really care what year it is I'm Guna turn it up anyways
Old 05-01-2013, 05:49 PM   #6
MadManAndrew
Turn it up? Lol Do you have any idea how the Duramax works? There are different generations of Duramax, the LB7, LLY, and LBZ all produced in the 99-06 model range. All came with their own specific features and problems. Some plaguing and some not so bad. None of them, however, had mechanically adjustable injection pumps. I warn you now: Do your research before trying to jump into a Duramax swap, or you WILL regret it.
1955 Chevy 3600 http://67-72chevytrucks.com/vboard/s...61#post8589061
MadManAndrew is offline   Reply With Quote
Old 05-01-2013, 06:03 PM   #7
82ccshorty
82ccshorty's Avatar
I meant it as injector and stuff. Not as pump adjustments. I know quite a bit about them
Old 05-02-2013, 01:52 PM   #8
MadManAndrew
You could easily put 600+ HP to the ground with a mostly stock motor (ie: CAI, exhaust, and a tuner). Injectors, modified pump, and any other performance mods like that are just overkill unless you're going for a drag machine. Try to avoid LB7 Duramaxes unless you like injector replacements taking ten hours. Other than that, good luck finding a wrecked Duramax, they're few and far between.
Old 05-02-2013, 10:55 PM   #9
clinebarger
LBZ or LMM.....6 speed Allison, Better ECM, injectors & no FICM.
Old 05-22-2013, 01:12 AM   #10
57ToyBox
57ToyBox's Avatar
Hey 82ccShorty
I drive an LMM as an every day driver and love it.
The older DMax that were plegged with the faulty injecters have either been fixed through warranty or the owners footed the bill to get them fixed. It's highly unlikely you'll come across one now.
Good luck in your search, as mentioned earlier. A wrecked Duramax that is for sale or on the auction block are few and far between. But if you come across one located in Ontario Ca. shoot me a PM. I'm looking for one too
57ToyBox is offline   Reply With Quote
Old 05-23-2013, 11:34 AM   #11
MadManAndrew
There were never any "faulty injectors". Injectors wear out and have to be replaced, that's a fact. The problem with LB7's is that the injectors are under the valve covers and take a ridiculous amount of time to replace.
Old 05-24-2013, 10:16 AM   #12
ghettoluxury
ghettoluxury's Avatar
Check out Hicksville Auto Recyclers, they are in Hicksville Ohio. I am not sure if they have a web site, but they are on facebook. They have a very nice all indoor wrecking yard and Duramax trucks is all they deal with. Probably the best place to find Duramax parts in the country.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
