Old 05-07-2013, 04:45 PM   #1
etindoll
Brake Line Question
I am in the process of swapping my 68 GMC over to front discs, and the donor truck that I have gotten my parts off of is an 87 model. The brake lines coming out of the MC on the donor truck had two loops in it do I need to keep the loops even though I am going to mount the prop valve in the same location as the factory 68 valve was. or can I just come straight out of the prop valve without the loops.
etindoll is offline   Reply With Quote
Old 05-07-2013, 05:17 PM   #2
Southcity
Southcity's Avatar
Re: Brake Line Question
Without a picture I am assuming that the loops you are referring to are when the brake lines sometimes have a coil-spring like loop bent into them as they leave the Master Cylinder. They are there to provide give for frame/body flex so the brake lines are not under stress, which could eventually cause the brake lines to crack. You can do it without the loops but would be nice to keep them there if possible.
66 GMC Suburban Custom
66 Chevy K10 Suburban
Southcity is offline   Reply With Quote
Old 05-07-2013, 05:46 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Why don't you want to run the entire 87 brake line system ? The proportioning valve mounts cleanly down on the little crossmember just like it did on the 87. Then you can run all of the lines, unmodified, from the 87 all the way out to the rubber hoses and calipers, from firewall to the wheels. It's a nice easy retrofit.
Old 05-08-2013, 08:30 AM   #4
etindoll
The brake lines that were on the donor chassis had been taken loose from the mc and were full of dirt dobber nest so I just got the prop valve since it wasn't hurt. I just didn't know if the looped sections of brake line were required or would it hurt to not have them.
Old 05-08-2013, 09:00 AM   #5
CC69Rat
CC69Rat's Avatar
That 'looped' line is also the same as a 69 Camaro with some minor adjustments Yes, I'd put it in there.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
