05-15-2013, 11:35 PM | #1 |
Lowering a 99 Suburban question
Got a 99 Suburban that I put in a 6' flip kit from McGuaghy's suspension, I put it on, also got lower shocks, before I ordered the short shocks I left the stock ones on, I called Styling trucks they recommended me Belltech lowering shocks and now it rides even worse then the stock shocks, does this need to be C notched ?
05-16-2013, 12:47 AM | #2 |
Re: Lowering a 99 Suburban question
Check and make sure that the shocks are not bottoming out. I had Bell Tech drop shocks on my 99' crew and the drivers side was too long. It was bottomed out when just sitting, the suspension wasn't even compressed.
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
05-16-2013, 12:57 PM | #3 |
I noticed yours was C notched thou, my question is if its totally necessary for me to notch the frame in order to have a decent ride on the burb with the flip kit it has on now..
05-16-2013, 03:10 PM | #4 |
Define "rides worse". Stiffer? Softer? Bottoms out? Bounces too much?
Rides worse is a subjective thing. I personally like a stiffer ride, less bounce. I hate my Moms Trailblazer. It bounces over even just speed bumps. She hates my GTA because over speed bumps it bounces ONCE then stop.
2001 Yukon Factory Grey Metallic~2" DJM Key front drop/3" DJM Rear Springs~stock 16" chrome steel wheels~5.3/4L60E~Volante CAI w/under bumper air scoop~Magnaflow 10426 Bullet muffler~DDM LED all exterior lighting/55w-5000k HID Hi/Low/35w Fog |
05-16-2013, 03:37 PM | #5 |
REALLY bumpy like a wild horse ,,,,,
05-16-2013, 04:00 PM | #6 |
Like the stock ones then? Bouncy bouncy bouncy not bottoming out or stiff & lack of cushion?
05-16-2013, 04:03 PM | #7 | |
05-16-2013, 04:04 PM | #8 |
Bottoms out.. specially with the lowered shocks.. Would the shock extensions help ? or do I need to C notch it... ? What about if I took out the bump stops ?
05-17-2013, 12:44 AM | #9 |
Anybody ?
05-17-2013, 11:03 AM | #10 |
You definitely need to take out the bumpstops and most likely notch it. I f I remember correctly the a le tune was very close to the frame on mine. The notches come with new bumpstops.
05-17-2013, 11:10 AM | #11 |
I'm gonna start by taking the bumps out.. and order a c notch any recommendations ?
05-17-2013, 12:32 PM | #12 |
My flip kit was from McGaughy's and it came with the notch. I would think they sell them separately as well.
05-17-2013, 02:40 PM | #13 |
laying low
I think first you need to identify what exactly is bottoming out. The axle on the bumpstops or the shocks. If the shocks are too long you can order different ones. If it's the axle on the bumpstops then you know what to do. You may need both.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
