Old 05-16-2013, 02:15 PM   #1
64LBSS
Dash Mounted Shifter
Hey Guys,
Going for a little custom touch on my 64 Longbed Step for the interior. I am going to do an engine and tranny swap and I will be installing a Turbo 350 tranny. I want to install a dash mounted shifter similar to what you find on a 67 corvair in the heater plate left of the radio location. Anyone try this or seen it? Ideas?? Thanks in advance !
BTW: I searched for almost an hour on here before posting this thread so if I missed it let me know.
64LBSS is offline   Reply With Quote
Old 05-16-2013, 03:31 PM   #2
FetchMeAPepsi
FetchMeAPepsi's Avatar
Re: Dash Mounted Shifter
I've never seen it but a dash shifter sounds really cool. I've got one in my Toyota Sienna (don't laugh!) and I really dig the short reach shifter on the dash.
If you do it post a bunch of pics!
Step by steps:
Remove primer to reveal original paint
Rebuild a carburetor
See My Build - Cecilia!
Some people are like slinkys. Not worth much but funny as heck when pushed down stairs.
FetchMeAPepsi is offline   Reply With Quote
Old 05-16-2013, 04:17 PM   #3
Indian113
Indian113's Avatar
Did the Corvair have a 3 speed trans? I thought they just had Powerglides.
Indian113 is offline   Reply With Quote
Old 05-16-2013, 04:18 PM   #4
Indian113
Indian113's Avatar
Dodge and Amc had pushbutton dash shifter's in the 60's
Old 05-16-2013, 04:51 PM   #5
1963c-10
1963c-10's Avatar
There were quite a few cars w/push button transmissions in the 50-60's
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 05-16-2013, 06:21 PM   #6
southern parts
southern parts's Avatar
I`ve seen a few dash mounted shifter in motor homes, usually on a dodge chassis. all you would need is the shifter and cable.
southern parts is offline   Reply With Quote
Old 05-16-2013, 06:31 PM   #7
64LBSS
Yep, that's what I've found is the dodge setup.. Now I jut have to find one and do some modifications.. I think it will be fairly unusual and unique.. If I can get the fit and finish to look right.. And not a hack job..
Old 05-16-2013, 07:15 PM   #8
vpersh
vpersh's Avatar
Automatic Corvairs all had Powerglides with no "park". You had to use the Parking Brake every time. There probably wouldn't be enough travel for a TH350 and the detents would be in the wrong place, plus the shifter was built into the instrument panel so you'd have to fab something to fit the truck. Your best best is the motorhome route.
Van Pershing
Tucson, Arizona
Idea Page
vpersh is offline   Reply With Quote
Old 05-16-2013, 07:23 PM   #9
64LBSS
I think I'll go the RV route, but anyone got ideas where to look? Nothing on eBay or any easily searchable item.. Anyone know of RV scrapyards in Atlanta area?
Old 05-16-2013, 07:35 PM   #10
Blue666
You can find them in the 1965-1968 Dodge A-100 & A120 vans. I had one in my 66 A100. They are for three speed auto's & work with a cable to the trans. Seem to remember the cable bolted to a bracket on the driver side of the trans, when you moved the shifter the cable got longer or shorter & shifted the trans.
When I switched the van to 3 on the tree, I tried to remove the cable shifter but it left a large hole in the dash. I put the auto shifter back & place & rigged a spring to keep the handle tight. To confuse people, I would shift the column shift, then shift the auto shift @ each gear change. If they got confused & they always did, I would explain it was a standard automatic.
http://vintage-vans.forumotion.com/t...ifter-for-sale Old post from a Dodge forum but gives you an idea of how they look. The van version had aslightly different bezel as the dash was different.
Blue666 is offline   Reply With Quote
Old 05-16-2013, 07:53 PM   #11
T Smith
T Smith's Avatar
Probably as scarce as hens teeth now but 70's AM General mail trucks had them on the dash and they were shifting 3 speed torque flites.
T Smith is offline   Reply With Quote
Old 05-16-2013, 09:40 PM   #12
southern parts
I looked at one yesterday. it`s in a scrap yard about 1 hr north of me. it would be about 2 hrs for you.
Old 05-16-2013, 10:27 PM   #13
markeb01
Senior Enthusiast
markeb01's Avatar
You might try searching under "Morse Controls". Back in the 70's I bought special shifters for the Peterbilts that were ordered with Allison automatic transmissions. They are also very common in boats, and there are many different varieties and styles to pick from. Some are surface mounted, other designs could easily be mounted behind the panel with just the stick visible to the user.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 05-16-2013, 10:50 PM   #14
rideblue00
rideblue00's Avatar
lol Blue666 "standard automatic"
rideblue00 is offline   Reply With Quote
Old 05-17-2013, 01:31 AM   #15
spacedebris
are either of these what your after?
http://www.ebay.com/itm/1971-AUTOMAT...9f85ab&vxp=mtr
http://www.ebay.com/itm/Dodge-Challe...item19d9712415
spacedebris is offline   Reply With Quote
Old 05-17-2013, 09:17 AM   #16
jbgroby
jbgroby's Avatar
Try this link
http://www.bing.com/images/search?q=...74&FORM=IQFRBA
jbgroby is offline   Reply With Quote
Old 05-17-2013, 09:29 AM   #17
hyatt
on my 46 I put a floor shift automatic column out of a 70s chevelle The cuff below key rotates and has a place to hook up shift linkage at bottom I simply rotate the cuff to put in gear and basicly have no shifter at all Good theft deterrent and gives people something to scratch their head about when they cant see a shifter
1946 car hauler
1948 surburban
1937 chevy sedan
1940 olds sedan (project)
1967 ss396 chevelle
1999 dually crewcab(24000 miles)
hyatt is offline   Reply With Quote
dash, mounted, shifter
