Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 06-05-2013, 03:15 AM   #1
76C10Stepside
76C10Stepside's Avatar
Towing Capacity?
Got a question for folks who pull travel trailers!
My '89 S-10 long bed has 1625 lb payload and the hitch is rated at 1750 lb max. Even small travel trailers are generally over 2000 pounds gross weight. Anybody know if the 1750 lb towing limit is absolute? For instance, is a 2000-2400 lb trailer with electric brakes too heavy?
If the S-10 is out of the running...
What's the towing capacity of a '76 C10 half ton? Mine had a 350 and a camper on it at one time. Campers are pretty heavy! It currently has a 305/T350 and no camper. I've pulled a car dolly with a 2400 lb car on it. Worked pretty well even with the performance radials. Not sure how long the trans and rear end will hold out though.
76C10Stepside is offline   Reply With Quote
Old 06-08-2013, 01:26 PM   #2
BarryB
BarryB's Avatar
Re: Towing Capacity?
I've pulled alot of weight with my lil s10. Wouldn't want to do it over a long distance , just because the trucks really weren't built for that. What motor and trans do you have? the 4.3 and 700r4s are what are in some full size trucks. If you have that, I probably wouldn't be scared to tow a 2000lb trailer.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 06-08-2013, 01:28 PM   #3
BarryB
BarryB's Avatar
I should say, I have towed a 18"car trailer with a fwd Oldsmobile on it, with an Astro van. Towed it no problem. 4.3 700 trans. 65- 70 on the flat interstate.
Two rules in life.
Old 06-09-2013, 04:18 AM   #4
76C10Stepside
I have the 4.3 with 4L60 4-spd auto. I'm confident that it will haul well within the designated limits. The ride/handling are very good. Would be nice to be able to lock the rear end on demand for better traction. Still wondering why throttle is so touchy from idle/standstill (worse when cold). Couple days ago it clunked when I threw it into reverse, sounds like a u-joint, but runs smooth and silent, need to check them.
Old 06-11-2013, 11:54 PM   #5
BlackedOut67shorty
BlackedOut67shorty's Avatar
Make sure you don't use your overdrive when you towing
1995 s10 blazer 4.3
1967 c10 350/350 fleet short
1993 s10 blazer 4.3l 4l60 RIP 6/20/14
2000 mercury sable
Thats a how I roll
BlackedOut67shorty is offline   Reply With Quote
