06-05-2013, 10:47 PM | #1 |
250 Parts & Power Steering Brackets
All of my spare parts are officially SOLD thanks Dave, it was nice meeting you, good luck with your stovebolt!
On to the parts! 250 Power steering brackets, these were pulled from a 69 impala (non-integrated head) SOLD in the lower 48. PN on the bracket that mounts below the PS pump is 3973156 and the smaller bracket with just 2 holes is 3973157 These brackets are complete as pulled off the car in the yard, I cannot recall exactly how the whole thing went together, please note that the Alt bracket (long slotted bracket) is chewed up, I am not sure what happened to it. Last edited by shelby2828; 11-06-2013 at 06:59 PM. |
06-05-2013, 10:52 PM | #2 |
Re: 250 Parts & Power Steering Brackets
Complete setup with everything but the Crank pulley, these were pulled from a "built" 250 motor I was going to swap into my truck...but alas, plans changed! I believe this motor was from a 1972 nova, but I cannot confirm the vintage of the brackets, but it was also a non-integrated head.
PN on the small slotted bracket is AAD-2782A01 / 354526 2 Groove WP pulley for a 250 PS setup PN 355776AX 250 PS pulley (and the pump if you want it). This came from the 69 Impala PN 3860457CV These are painted and ready to go, just a bit dusty and crusty $old! Last edited by shelby2828; 11-06-2013 at 06:54 PM. |
06-05-2013, 10:55 PM | #3 |
SOLD
Monojet Rochester Carb, I pulled this in favor of a 4bbl "economaster" carb...BIG mistake, lost a lot of low end torque! This has a manual choke and was on a running truck, but has been on the shelf for 7 years, so a rebuild would probably be a good idea. $45 plus shipping. Last edited by shelby2828; 06-06-2013 at 11:00 AM. Reason: Item Sold |
06-05-2013, 10:56 PM | #4 |
See above
06-05-2013, 10:58 PM | #5 |
250 Steering Arm (not sure if this transfers to a 2wd truck or not) again, from the 69 Impala
PN 941796 SOLD Last edited by shelby2828; 11-06-2013 at 06:55 PM. |
06-05-2013, 10:59 PM | #6 |
250 "turbo fire" 1bbl intake air cleaner
$35 plus shipping. SOLD Last edited by shelby2828; 06-09-2013 at 11:32 AM. |
06-05-2013, 11:00 PM | #7 |
Moved Above
06-05-2013, 11:01 PM | #8 |
250 Cast iron exhaust manifold in good shape, no cracks, this came from my 1970 K20
$OLD Last edited by shelby2828; 06-12-2013 at 04:10 PM. |
06-05-2013, 11:02 PM | #9 |
06-05-2013, 11:03 PM | #10 |
250 Throttle linkage (3 on the tree truck if it matters)
$15 SOLD Last edited by shelby2828; 06-12-2013 at 04:10 PM. |
06-05-2013, 11:04 PM | #11 |
Motor Mount (I wish I could remember which side) This is off of the same nova engine.
SOLD Last edited by shelby2828; 11-06-2013 at 06:56 PM. |
06-05-2013, 11:06 PM | #12 |
Alt pulled from the Nova Motor, I don't believe it has ever been run, there is some oxidization from sitting.
SOLD Last edited by shelby2828; 11-06-2013 at 06:57 PM. |
06-05-2013, 11:08 PM | #13 |
Would you do 40 shipped on breather?
06-05-2013, 11:11 PM | #14 |
Also, not pictured I have a power steering box for a 67 4x4 that I dismantled in an attempt to rebuild it, and lost interest when I discovered it was beyond me! $10 plus shipping (some assembly required)
06-05-2013, 11:33 PM | #15 |
I'll take the Rochester carb...PM inbound.
06-05-2013, 11:43 PM | #16 |
Please include your zip when requesting a shipping estimate (either in pm or reply)
Thanks! Posted via Mobile Device |
06-06-2013, 09:24 AM | #17 |
All PM's replied.
06-07-2013, 09:33 AM | #18 |
I have had a couple of questions about the exhaust manifold, the heat riser swings freely without binding, and opens quickly (albeit a bit squeaky) and completely from manually closing it.
06-08-2013, 08:45 PM | #19 |
Bump for the 250 guys, if it is still pictured, it is still available.
06-12-2013, 04:11 PM | #20 |
Exhaust and linkage sold, ps, and intake still available.
06-16-2013, 08:08 PM | #21 |
Weekend bump
06-23-2013, 03:10 PM | #22 |
Ttt for all us stovebolt guys!
06-24-2013, 08:11 AM | #23 |
Shelby,
Do you think any of your stuff will fit my stuff. http://67-72chevytrucks.com/vboard/s...27#post6139527 My motor is from a 73 nova I don't want to go to the junk yard again and don't want to put down $200 for something that won't fit. Posted via Mobile Device |
06-24-2013, 09:11 AM | #24 |
Dirt, the painted set came off of an early 70's 250 setup (the brackets and the double groove pulley) I bought the engine out of the car, but I do know that is what it was intended to go into.
I cannot speak to any issues there maybe with the pump, I think they should all mount the same way (for a 250), but I am by no means a stovebolt expert. I will ship the pulley and brackets together for the asking price. Posted via Mobile Device |
07-01-2013, 12:43 PM | #25 |
Bump
