Old 06-08-2013, 10:31 PM   #1
jbassC10
Smile Help on Restoration?? 69C10 388Stroker
I'm in the process of converting drums to disc in the front end and newer drums in the rear of my 69.
I have now for this process of the summer project:
-71 front end disc to swap with my original front end
-93 Rear end axle with 98Drums
-?-My radiator is of course old"." So I'm wanting to update it to newer, nicer radiator and to find a $cost a college student can afford!? (Me, full time/off for the summer)
-----Any ideas on what year I can search for to swap out my radiator with another one? As well as an ideas on a site I can shop off of to swap without a lot of modifying?
Any tips would be awesome! Defiantly on the conversion of drums to disc???
jbassC10 is offline   Reply With Quote
Old 06-09-2013, 12:33 AM   #2
luvbowties
luvbowties's Avatar
Smile Re: Help on Restoration?? 69C10 388Stroker
Many of us on forum have bought the aluminum (Champion brand, iirc) rads from Ebay--approx. $150-$175, shipped, and are a direct fit with no mods needed. They're prolly cheaper than having yours re-cored PLUS it is brand new PLUS it is aluminum with excellent cooling for whatever eng. you may ultimately install.
We've personally used several on 60-66 and several 69-71 pickups and also on some tri-five chevy's and on some sixties-Cadillacs and Pontiacs, all with good results after several years' use.
As far as disc swap, if your '71 front end is in good shape, it'll be more straight-forward to swap entire crossmember and avoid trying to match 'shafts and holes'.
Keep in mind: u can save some $ on new caliper hoses by buying from Rock Auto on the web--like $15 for a pair. Compare that to local stores, and even w/shipping you'll likely save considerably.
HTH,
Sam
luvbowties is offline   Reply With Quote
Old 06-10-2013, 12:46 AM   #3
jbassC10
Hey!
Thanks so much!! I'll try to check out that website and save some money for sure!!
And no luck on swaping the whole front end cross member. I only bought the front 71 A arms. So it sounds like I'll have to see what I can do to mount them up.
Again, Thanks sooo much!!
~Tyler
Old 06-10-2013, 01:14 AM   #4
jbassC10
Would this one work by chance?
http://www.championradiators.com/Che...r-V8-1967-1972
Old 06-16-2013, 09:28 PM   #5
jbassC10
Thanks again! I got a new radiator on its way!!!
20s, disc, radiator
