Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 06-25-2013, 05:02 PM   #1
jmcleek
jmcleek's Avatar
fuel pump problem
What would make the fuel pump run all the time key on, engin off and key in accessery? Don"t run key off. This is on a 97 Blazzer. Fuel pump relay is in the glove box relay center left hand side?
jmcleek is offline   Reply With Quote
Old 06-25-2013, 05:24 PM   #2
rambler
MOVE OVER
rambler's Avatar
Re: fuel pump problem
not sure what relay it is, I believe it is the farthest left in glove box,, closest to driver.. but my assumption is it would be the fuel pump relay
No matter where you are..... There you are...
Buckaroo Banzi
rambler is offline   Reply With Quote
Old 06-27-2013, 05:06 PM   #3
jmcleek
jmcleek's Avatar
Had a new problem, a no start probem with the fuel punp running, Fixed this probem the first problem went away. (Low fuel pressure) Replaced the fuel pump , and all is good.
Also have a link for you http://troubleshootmyvehicle.com/gm/...he-fuel-pump-1
john
