06-30-2003, 01:03 AM | #1 |
Bags any good on a daily driver???
I'm thinking of bagging my 72 short wide, but I want to drive it every day. Haul parts, tow trailers... that kind of thing. I had a static dropped 90 with air lift bags that I liked, I like the idea of being fully bagged. Any advice?
06-30-2003, 02:39 PM | #2 |
over the road trucks (semi's) have used them for umpteen years with out problems
The kid Build threads: 51 Jimmy http://67-72chevytrucks.com/vboard/s...d.php?t=154951 http://67-72chevytrucks.com/vboard/s...d.php?t=219902 http://www.classictrucks.com/feature...uck/index.html 68 C10 http://67-72chevytrucks.com/vboard/s...ad.php?t=50348 |
06-30-2003, 10:39 PM | #3 |
if you want to pull a trailer and haul stuff there is no better reason to bag it, add a little more air and you can load it up with a trailer and not be on the bumpstops
06-30-2003, 11:26 PM | #4 |
belly dragger
Bag it and you'll wonder why you hesitated. Garuntee you'll be alot happier with the ride. I have a 92 chev for a daily driver thats bagged and its great even in da snow
06-30-2003, 11:33 PM | #5 |
I've had bags on the rear of my daily driven 68 for 3+yrs now w/o problems. Fronts shouldn't be any different (sorry, but I run spindles w/cut coils on mine). Only worry would be keeping the air psi/settings consistent w/the setting it is aligned with to prevent premature tire wear.
