Cams, OE grinds available?
I am in the midst of sprucing up Mighty Joe for my daughter to drive. I need (amoung other things) a new cam.
The truck is very close to stone stock so I would prefer to install a cam that is ground to oe specs. Joe is a 68 C20 327 4bbl th400, rear gears not known, but very low (411/456). Thanks guys!
Just remember, everything has two edges. |
user # 2756
![]() Join Date: Jun 2001
The new LMC catalogs have cams w/ stock profiles. Order a catalog: www.lmctruck.com
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() |
Thanks man, I'll check them out.
Ps. Pwr drums all the way around, no fear!
How's the reputation of Clevite (sp?) camshafts? I found through Kragens a cam, lifter, and timing components kit for roughly $200. I've used clevite bearings and they seem to have worked fine.
I am also considering going a little further in this project and pulling the engine entirely so I can replace the rear seal and pan gaskets too. Then I reckon I better do a torque converter seal and trans pan/fluid change. Geeze, how it snow balls. Anyone got tips to offer on the rear seal? I've never replaced one these old two piece arrangements before.
its all about the +6 inches
you can get them quite a bit cheaper than that.
3 years ago i went to O'Riellys and they had a stock cam for 40 bucks and lifters for another 30....this is a 3 year old memory on numbers (which I totally suck at) but I remember saying it was cheaper than a $99 performance grind...so those numbers must be clost to right. |
CCRider
With a rear gear like that I would look at a cam to help out with gas milage. Unless you buy a nos GM cam you are not going have a stock cam anyway, you will have whatever fit-all they have sitting on the shelf.
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
Fabricate till you "puke"
You might lok at the Crane Energizer series. The 266 should work well with your app, & will have a "stock type" smooth idle. The cam & lifter kits should be available through Summit racing, Jegs, or northern auto parts for just a tad over $100. I have run the energizer cam kits in several trucks/cars & have been very pleased with the end results. Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Crane has an OEM line of cams as well.
Registered Cruiser
The las time I bought one of these (300hp 327ci) it was about $80 for cam and lifters. It's a good low cost camshaft.Crane Cams oem performance cams
I intend to live forever. So far, so good. |
