Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The pre 1947 Chevrolet & GMC Truck Message Board
Old 07-09-2013, 05:16 PM   #1
JenniferKillby
1946 Chevy - Front Sub Frame
Hello Everyone
We're restoring a 1946 Chevy Truck and are looking at front subframes for modern handling. We have heard they are using the Crown Victoria for the Fords. Do you guys have any suggestions as to what modern subframes would fit a 1946?
Thank you for your help.
I have a photo of the truck attached.
Jennifer
JenniferKillby is offline   Reply With Quote
Old 07-09-2013, 07:21 PM   #2
old yelr
Re: 1946 Chevy - Front Sub Frame
Hi, welcome to the forum
Flat Out Engineering makes a weld in front IFS crossmember as well as Progressive Automotive and they both have kits for idependant rear suspension as well if you are planning on going that route.
Here are the links:
www.progressiveautomotive.com
www.flatout-engineering.com
Hope that helps!
old yelr is offline   Reply With Quote
Old 07-09-2013, 08:47 PM   #3
Scottshotrods
As well does Scotts Hotrods has full ifs kits built for your truck.There are two different builds on this site showing both Frontends
1.Chizzler
2.Paintman
Scottshotrods is offline   Reply With Quote
Old 07-09-2013, 08:54 PM   #4
JenniferKillby
Thanks Old yelr and Scottshotrods. I appreciate your help. I'll take a look at those.
Old 07-09-2013, 09:00 PM   #5
old yelr
Oops, and Scottshotrods who is an awesome board member who is always ready to help in any way possible!! My bad.
Old 07-13-2013, 03:45 PM   #6
Bo Duke
Bo Duke's Avatar
Originally Posted by JenniferKillby View Post
Hello Everyone
Jennifer
Crown Vic is going to be too wide for this year of truck. If you want to use a full front sub-frame on a budget look into into S-10 trucks. Otherwise there are a lot of companies that make Mustang II front suspension cross members that weld onto the stock frame.
1939 Chevy 1/2 Ton (30 year long father/son project)
1997 Jeep TJ on 1 tons
2011 Cummins
1972 GMC Jimmy
Bo Duke is offline   Reply With Quote
Old 07-13-2013, 11:38 PM   #7
3drburb
Depending on your budget you may be able to use a full late 80s S-10 suspension (redoing body mounts), mid 70s nova or firebird front clips.
3drburb is offline   Reply With Quote
