Old 07-13-2013, 11:35 PM   #1
Doktor Hug
65 power steering conversion, with photos!
Here's the victim, partway through bodywork:
I ordered the power steering box adapter plate and the tube and flange from Captinfab. Quality, precision work. Highly recommended! I did the whole conversion with junkyard parts.
remove old steering box (like, literally this took the most time for the whole project:
Cut out the template that comes with the stuff from Captinfab, and punch the holes for the adapter plate. (the bottom right hole is tricky, since it's so close) I ended up putting the drill bit in the old hole and leveraging it down to make the new hole. Yes, it's a good way to break bits...
Test fit the plate. It's really nice how the notch is in the bottom right...no weird grinding of supports.
Mounted the box. Made note of what to cut from steering shaft, as I didn't pre-measure like in the destructions. Removed and cut shaft.
I have newer heads on my truck, so I had holes for accessories, but my replacement water pump didn't have the hole threaded for the mount. I ran a bolt and nylon washer through it. BE SURE to grab the brackets from the same truck you get the pump from. I got mine from 2 different trucks, and they weren't the same. Took 4 trips to the yard to find a matching pump/bracket set. Get it all from the same truck at the same time, or take photos of your bracket/pump to match. I also cut off the A/C mounts on these brackets:
Next I bought a bunch of parts. I just got the same parts from the donor truck new. This is all 75 chevy stuff. Do note the standard/metric cutoff, and be sure to check at the yard what you're getting. New hoses, fluid, belt.
installed the hoses. I ran the return line under the pressure line to avoid getting worn on the bottom edge of the fender.
fit the pump easily (vertigo looking up view):
I didn't take a photo, but I drilled a hole through the tube flange and shaft and ran a bolt/nut through them. I found a cool stop shaft at ACE that had a clip on the end, but drilled the hole too big, and didn't like the idea of any slop.
A junkyard Grant GT find tightens up the interior side. This got confusing taking it apart, but I blame extreme hunger. I had to replace my turn signal since I was in there, and it wouldn't go back together right.
Overall, I'd say this took 10-12 hours to complete. 3 of that was easily trying to take off the old box. My impact wouldn't get it to budge. I also spent a couple hours on the wheel, painting some stuff and getting hunger confused replacing the turn signal piece. Did it all by myself. Someone helping would drastically cut the time down, as I found myself going from engine to under a whole bunch of times doing the pump.
Hope this helps anyone looking to swap themselves!
Keep the rubber side down!
Doktor Hug is offline   Reply With Quote
Old 07-14-2013, 12:46 AM   #2
Fastest32
Fastest32's Avatar
Re: 65 power steering conversion, with photos!
Great thread. I just finished up the same process today. Still working out the fan on the new water pump pulley issues though.
BaBaBooey BaBaBooey
GO SPURS GO!!!
Fastest32 is offline   Reply With Quote
Old 07-14-2013, 09:13 AM   #3
williamsboys
williamsboys's Avatar
Awesome. Great photos , step by step. I will be doing this very soon as well
Williamsboy
williamsboys is offline   Reply With Quote
Old 07-15-2013, 01:47 AM   #4
Captainfab
60-66 Nut
Nice job Doktor Hug
Thanks for taking the time to post this step by step.
Old 07-15-2013, 02:07 AM   #5
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Great job with the instructions and pics.
Now start a thread with more pics of your truck.
66 C20 Service Truck:
Old 07-15-2013, 02:26 AM   #6
gofastnut
gofastnut's Avatar
Truck looks good! Thanks a lot for posting pics-in-the-process.
Keep up the good work!
Jeff
96 C3500 Crew Cab Long bed (Waiting on Cool Name)
64 C-10 shortie stepside, "Ole Brownie"
C-10 Club
My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345
gofastnut is offline   Reply With Quote
Old 07-15-2013, 10:37 AM   #7
JWheeler331
JWheeler331's Avatar
Ordered mine from Cap the other day so I will be doing this soon.
JWheeler331 is offline   Reply With Quote
Old 07-18-2013, 10:19 AM   #8
Mike K
Mike K's Avatar
Just drove mine after doing this conversion. What a difference!!!
66 Chevy C-10 SWB, 250-L6, 3-speed manual OD
Mike K is offline   Reply With Quote
Old 07-18-2013, 12:24 PM   #9
chevyrestoguy
chevyrestoguy's Avatar
One of the best mods you can do on a '60-'66. Captainfab's brackets are outstanding. I've got one of his steering box adapters and one of his power brake booster adapters.
Upgraded your brakes yet?
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 07-18-2013, 12:26 PM   #10
Doktor Hug
yeah, last year I did the CPP 3/4 ton brake upgrade with dropped spindles.
Old 07-18-2013, 01:49 PM   #11
1963c-10
1963c-10's Avatar
x2 on the brake adapter.....power steering will be next. Top notch parts
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
power box swap, power steering conversion
