Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The pre 1947 Chevrolet & GMC Truck Message Board
Old 07-14-2013, 11:38 AM   #1
Bo Duke
Bo Duke's Avatar
1939 Cab Mounting
I've got a basket case 1939 Chevy pickup. I'm trying to just get this thing all bolted together to see what I've got to work with and take up less garage space. I've got the new cab mount kit from Jim Carter, but something's not fitting right.
Starting at the front, I've got the liners under the first two cab mounts. The 3rd has a liner and the wood block. The fourth is supposed to be the rubber bushing, but there's a 3/8" gap between it and the cab floor. Am I missing some part of the steel cab mount? The original wood blocks from the 3rd mount fit perfect so I used them to support it for now.
None of the bolts are tight yet.
Second question, what is this CB206 body mount? I can't tell where it's supposed to go.
1939 Chevy 1/2 Ton (30 year long father/son project)
1997 Jeep TJ on 1 tons
2011 Cummins
1972 GMC Jimmy
Bo Duke is offline   Reply With Quote
Old 07-14-2013, 11:43 AM   #2
Bo Duke
Bo Duke's Avatar
Re: 1939 Cab Mounting
I found this diagram, it shows the rear cab mount has a recess to it? The rear of my cab is flat
http://www.stovebolt.com/techtips/cabmounts.htm
2011 Cummins
1972 GMC Jimmy
