Old 07-14-2013, 05:02 PM   #1
shortbed70
shortbed70's Avatar
Lmc under bed tank?
Lets see how you mounted yours! I don't like the way the straps are so short so I'm thinking of something different...
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 07-14-2013, 07:28 PM   #2
T2vigil
T2vigil's Avatar
Re: Lmc under bed tank?
I don't have photos but what I did on my 64 stepper is as follows: Removed bed and trimmed the cross bed piece as necessary to clear the tank. Drilled holes through the frame and tack welded four 1/2" bolts for the tank. I cut a piece of an old tire, 1.5" by 12" to fit over the bolts. Then used the piece of tire as a vibration tamper and double nutted the tank under the frame. BTW I had to bend the top of the frame rail to accomodate the filler hose. I will post photos after my grandson is born. Wife has the camera and is with our daughter playing the waiting game.
T2vigil is offline   Reply With Quote
Old 07-14-2013, 07:54 PM   #3
shortbed70
shortbed70's Avatar
So you did the 21 gallon? I bought the 17 and it lines right up with the holes in my frame already. I didn't want to mess with a filler tube and stuff so straight through the bed for me. I look forward to seeing pics. Congrats on the grand kid also...
Troy
Big Red Dog build
Old 07-14-2013, 08:22 PM   #4
T2vigil
T2vigil's Avatar
I used one of the pop-up motorcycle tank fillers on the side of the fender. I used some old 1.5" exhaust pipe and some flexible hose from Lowes to make the connection to the tank. It turned out pretty good. Now all I have to do is run some of the fuel out so I can make the connection to the new tank. And thanks for the congrats. Our daughter is only 5 hours away so I am ready set waiting for the call from my wife.
Old 07-15-2013, 09:16 AM   #5
kieth
kieth's Avatar
We used the 21 gallon blazer fuel tank, we did not want to use the side filler neck either, so we took the filler neck from a 91 blazer and welded it into the bottom left (top) of the tank, filled in the old filler neck , mounted a in the tank fuel pump for TBI and then cut the hole in the floor to fill the tank. Here are the links and details:
start of process--drilling hole and getting ready to install new filler neck:
http://kieth.smugmug.com/Trucks/66-G...t3RHj&lb=1&s=A
after mods:
http://kieth.smugmug.com/Trucks/66-G...TFcBh&lb=1&s=A
installed in floor of bed:
http://kieth.smugmug.com/Trucks/66-G...0690&k=5cxcPkV
Look around in the build and you will see more details scattered throughout.
kieth is offline   Reply With Quote
Old 08-01-2013, 10:30 AM   #6
shortbed70
shortbed70's Avatar
Update!!! Got the tank in filler neck modified but my next issue is what to do on the vent line!
Troy
Big Red Dog build
Old 08-01-2013, 11:36 AM   #7
T2vigil
T2vigil's Avatar
Since my filler cap is non vented I used a cheep fuel filter. I put about a foot of hose on the tank with the filter on the other end and tucked up out of the way of wheel splash.
Old 08-01-2013, 11:57 AM   #8
billd5string
billd5string's Avatar
Does the bed have to come off to mount the tank? Or can it be installed with the bed in place?
65 C20 Fleetside longbed, 350, turbo 400, 8-lug disc brakes, power steering, air conditioning - Totaled by a guy running a red light. Pulling parts off the carcass for my next truck
billd5string is offline   Reply With Quote
Old 08-01-2013, 12:10 PM   #9
shortbed70
shortbed70's Avatar
Tank goes on the bottom side of frame so having the bed in wont hurt me. I actually will probably have to drop the tank to mount the bed floor
Troy
Big Red Dog build
