Longtime Member
Problems with board?
I will admit I haven't been logging on as much lately (busy, busy) so I might have missed something. I'm trying to search the board for a post I submitted a while back. Someone else on the board (can't remember who) said they would show me how to cut a slot in a van column and weld a tab to the shifter tube so I could use the original backup light switch. BUT, the board won't let me perform a search. I know I used to be able to do this, why not now? Jus' wonderin'!
Rokcrln - "I'm a major car addict so trying to go as low buck as possible is like asking a coke head to use flower to save money." 1972 C10 Short Step -http://67-72chevytrucks.com/vboard/s...d.php?t=261405 |
![]() Join Date: Oct 2001
search has been temporary disconected!
Things happen for a reason! |
CCRider
I have that saved, it was by JimKshortstep4x4:
JimKshortstep4x4 Senior Member Registered: Jul 2001 Location: Kentwood,MI,USA Posts: 1259 We make the van tilt neutral safety switch slots the same dimensions as on the column. It is located 8" from the lower end and centered in line with the old switch slot. We weld a 1/4x1/4 angle to the shifter tube which is 1/2" long as in the pic. Once the angle is in place we put the neutral safety switch in neutral and the shifter in neautral. The small slot on the neutral safety switch fits over the verticle leg of the angle which orients the switch. We then drill the two screw holes so that they are located in the middle of the adjustment slots on the neutral safety switch, just in case some adjustment is needed. The nice part of doing it this way, the factory wires plug in and there is no interference with the mounting of the column. Jim
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
