Old 07-22-2013, 09:58 AM   #1
Thefojizzle@me.com
Floor to column shifter
Hi,
I have a 700R trans with a B & M ratcheting floor shifter. My column is the original "3 on the tree" manual. I was wondering if anyone has had the experience of changing the shifter on to that column? My buddy who works on transmissions looked at my truck and said it would be an easy swap and would help me. I just wanted to make sure. I went to the "Truck Shop" and bought a 17" conversion rod to make the swap. Once I swap it, ill sell the B & M. Anyone with any advise for me? I was gonna go with a Lokar floor shifter (tall one) but decided to clear up the floor space instead and have it look more stock by throwing it back on the column. Any advise/tips would be appreciated!
Thanks again
Thefojizzle@me.com is offline   Reply With Quote
Old 07-23-2013, 11:51 AM   #2
1963c-10
1963c-10's Avatar
Re: Floor to column shifter
So your trying to convert a 3 speed manual column to an automatic column shift?
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 07-23-2013, 12:11 PM   #3
Thefojizzle@me.com
No, trying to take my 4 speed 700r trans shifter from the floor, to the column. My other option is to just put a Lokar 16 or23" auto floor shifter.id rather put iron the column, more original and frees up floor space.
Old 07-23-2013, 04:34 PM   #4
1963c-10
1963c-10's Avatar
I personally think your best bet would be to find a four speed column shift that was available on a lot of vans 70's-80's. I don't know that you can convert the 3 speed manual column to work w/4 speed auto. Im not saying its not possible, just haven't heard of it. I have seen a lot of guys use the 2 speed auto columns on 3 speed autos, but most of the guys I've seen w/4 speed autos go to a newer or aftermarket column.
Old 07-23-2013, 04:49 PM   #5
Thefojizzle@me.com
Thanks for the options. Ill look into it
Old 07-25-2013, 12:41 PM   #6
Thefojizzle@me.com
So, yesterday I pressed in with the conversion. Bought a $40 kit from the truck and car shop in orange and started the installation. Luckily all the tabs for the 3 speed manual were still on the steering column and they never filled the shifter hole. The kit for converting had a rod that was too short. Bought a piece of steel rod and a hardware store $4 and cut and welded on the threads from the rod in the kit. A couple of other little bends and about an hour later i had it done. It took longer to remove the old shifter out of the cab than it did to make the conversion! Stoked! I know guys think a floor shifter is better but I prefer the more stock look to the truck and it frees up space so the old lady slide over next to me while cruising!!
Old 07-25-2013, 01:54 PM   #7
1963c-10
1963c-10's Avatar
Im glad you were able to figure it out. Post some pics for us as this is a conversion I am unfamiliar with.
Old 07-25-2013, 02:25 PM   #8
Thefojizzle@me.com
Haha! Yes. I tried but it keeps telling me the pics are too large. They are pics I took with my iPhone. Having trouble resizing. Is there an app I can use for that?
Old 07-25-2013, 03:27 PM   #9
1963c-10
1963c-10's Avatar
I download them to my computer, then resize off my computer.
Old 07-25-2013, 04:06 PM   #10
Thefojizzle@me.com
Ugh.... What a pain
Old 07-25-2013, 05:14 PM   #11
Thefojizzle@me.com
Old 07-25-2013, 05:18 PM   #12
Thefojizzle@me.com
The first pic is a **** if the inside.
Second is a shot from the column down to the trans. Found an app that resizes your pics right on ur phone. It's called "smarpon" from the App Store. Free and worksPosted via Mobile Device
Old 07-25-2013, 05:19 PM   #13
Thefojizzle@me.com
Pic of the inside!!! Apparently my phone has already learned how to auto type my filthy language
column, conversion, shifter, swap, transmission
