07-26-2013, 07:40 PM | #1 |
Turbo setup for a 5.3
I came upon this video from justchevytrucks on youtube. I want to try this setup on my 5.3 when I swap it in except i'll have an intercooler on mine. Does anyone have a turbo setup similar to this one or is there a better way to go about it? Post pics if u guys can.
heres the video... |
07-26-2013, 11:42 PM | #2 |
meowMEOWmeowMEOW
Re: Turbo setup for a 5.3
Maybe its just the way it seems laid out but it seems weird to me to have the exhaust feed INTO the other manifold. I haven't seen that before. Usually the seperate manifolds merge, I'm not sure what a dual-purpose manifold like that what really do.
Never seen that before.
07-27-2013, 12:30 AM | #3 |
I hadn't seen that setup before either until I started digging around for a turbo kit for my Silverado. It appears that it's the standard layout for most of the newer chevy truck single turbo kits out there. KB Racing and Trick Performance, the two largest producers of silverado turbo kits, both utilize that setup. You can actually purchase that manifold separately from Trick performance if you're building your own kit (for a mere $600!).
Check out these sites, they show more on these kits: http://www.shop.trickperformanceprod...1.htm?page=all http://www.kbracing.net/about.html I've thought about using one of these kits on my C10. The only real downside I see is that you have to use the stock truck manifold on the drivers side which doesn't fit real well.
Will 1970 CST10 SWB LQ4/4L80E 2004 Silverado (sold) 2007.5 Dodge Ram 2500 |
07-27-2013, 04:02 PM | #4 |
meowMEOWmeowMEOW
No disrespect to KB racing, but I've seen a mix of things come out of that place.
The manifolds are schedule 40 pipe, which is fine for strength but lacks the elegance of stainless for a turbo manifold. They came a long way from where the used to be, but I still get a "diy" vibe on some of the parts quality. That being said; if it works, it works. I'd be interested to hear if any high-hp guys are running this. Is there a negative side effect from having 4 cylinders push air 3ft to the turbo, wherease the other 4 push the air 4 inches to the turbo.
07-27-2013, 11:36 PM | #5 |
Trick has a new cast stainless manifold. People have made lots of power with that type set up.
82 c10 5.3/4l60 84 c20 5.3/sm465 85 chevy k10 suburban LQ4/4l60 91 chevy c10 suburban Lsa 5.3/4l60 2017 Silverado whipple 5.3 1964 Vw beetle 1974 vw beetle |
07-28-2013, 01:56 AM | #6 | |
meowMEOWmeowMEOW
Equal length runners from head to turbo will almost always make a little more power, and do so a little more efficiently....but this effect has somewhat of a diminished return on a big v8....why? Exhaust leaves the head in a pulse, not a single stream of air. These pulses have a certain amount of force inside a pipe, and thusly take a certain amount of time to travel the distance to the turbo. On a small engine like a 4 cyl turbo, there are only 4 pulses being generated, so if one runner has a significantly longer path, it has a greater effect on the amount of air being delivered to the turbo. From what I can find its similar to the idea of scavenging exhaust in terms of squeezing the maximum effort from the air. The more cylinders and larger engine, the more frequent and larger the pulses, making the issue of equal runners less imperative. I still think its weird to force air towards the outlet of a head, but at least the runner length thing has an answer.
07-28-2013, 09:26 AM | #7 |
The highest I found in my quick look is 919 hp to the ground threw a 4.8 with stock internals.
07-28-2013, 10:57 AM | #8 |
Ive been researching for a while... I'm going custom so i know it fits and works and looks good.. Plus i want to show it and race it... but very expensive my route that's why its taking so long...
http://67-72chevytrucks.com/vboard/s...d.php?t=494388 431 big block times, changed to a 6.0 ls with turbo 1.58- 60' 7.18- 1/8th mile@95.18 11.37- 1/4 @115.81 |
07-29-2013, 12:05 AM | #9 |
found this video...pretty much the same setup except with an intercooler
08-01-2013, 03:35 PM | #10 | ||
Boosted Member
It was pretty janky, but it worked well enough to push my 5.3 powered longbed into the high 11s on a junkyard semi-truck turbo. Quote:
Here's a stock pass side GN manifold And here's a set of GN1 aftermarket stainless headers.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
