07-27-2013, 04:43 PM | #1 |
Chassis paint help!!! :(
Hi all i just got done sand blasting and painting my 64 Chevy truck frame with "eastwood company chassis kit (epoxy primer x2 coats, and their signature 2k ceramic black chassis paint)
PROBLEM = the paint scratches like nothing, just putting the frame on jack stands has the paint scratching off. I waited 2 days for paint to dry and its been 5 days and its still scratches really easy. the reason i bought the stuff was they advertised that it was super durable. i used all their products and cleaned the frame like they instructed....im at a loss if anyone has any ideas please help
overspecialize and you breed in weakness... |
07-27-2013, 05:15 PM | #2 |
Re: Chassis paint help!!! :(
Is that epoxy not a two-part mix of epoxy and activator? Was it mixed exactly as recommended?
07-27-2013, 05:20 PM | #3 |
yes it was 2 part 1:1 mix, in a paint cup like the instructions said and the black was a 4:1 with activator used in paint mix cup... im no pro and im not above thinking it was human error but i followed their instructions and used only their product to clean and paint the frame not sure what else i could have done it seemed very easy
07-27-2013, 05:31 PM | #4 |
I'm not familiar with Eastwood's product line, but catalyzed stuff in general gets pretty darn HARD. Can you tell if it's the primer, or paint (or both) that's still soft?
07-27-2013, 05:42 PM | #5 |
It goes right down to bare metal so I assume it's both
07-27-2013, 07:33 PM | #6 |
07-27-2013, 07:36 PM | #7 |
I heard this stuff is pretty good.http:// https://www.por15.com/mobile...t.asp?itemid=8
Posted via Mobile Device |
07-28-2013, 10:15 AM | #8 |
I too a specific chassis paint from Nisson and is disappoint with it. Next time ill use 1-stage paint and primer. IMO
07-28-2013, 02:32 PM | #9 |
I use regular black rustoleum on mine, the stuff is bullet proof when dry, you can hit it with a hammer with no damage.
past trucks: 1980 C-10 Silverado SWB 1961 C-10 custom cab LWB 1966 C-10 custom cab LWB |
07-28-2013, 03:01 PM | #10 |
Who Me?
Id use POR 15.
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
07-28-2013, 05:19 PM | #11 |
Chevy addict
Call Eastwood, they should be able to lead you in the right direction, I'm sure it's happened before.
07-28-2013, 10:58 PM | #12 |
And maybe get a video of how easy it flakes off.
66 shorty |
07-29-2013, 12:50 PM | #13 |
How long did you wait between spraying the epoxy and paint? If you got the paint on too soon over the epoxy then that could be the problem.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
07-30-2013, 07:54 PM | #14 |
I waited 24 hrs which is in the window for what the instructions say
07-30-2013, 08:52 PM | #15 |
Sounds like the hardener for the epoxy may have been bad. Check to see of there is a batch or lot number and call Eastwood to see if they've had problems.
07-30-2013, 09:14 PM | #16 |
Use POR 15. Check out my build thread below. Super strong
Glenn
Glenn Korec Jamesville NY 64 C20 350ci Turbo 350 tranny 3.73 gear with air ride. 61 Apache10 (wife's truck) 327ci powerglide. http://67-72chevytrucks.com/vboard/s...d.php?t=570100 |
