Old 08-10-2013, 01:24 PM   #1
'63GENIII
'63GENIII's Avatar
63" Rear spring swap
I'm looking for some input on a project I'm gathering parts for. I'm going to swap my rear springs out for the 63" newer versions in an attempt to get a softer ride out of my truck. I have a chance to get 2010 1/2 ton springs, 2006 3/4 HD or 60" 3/4 ton suburban springs. All are the same price. That said, would I be better off running the 1/2 tons and air bags for when I have to haul stuff, the 3/4 HD's and removing leafs to tune the ride or the suburban springs? All are the same price, newer style and 2.5 wide. I'm also setting up to run 52" springs in the front for the same reason. Your thoughts? Thanks for any advice!
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 08-10-2013, 11:53 PM   #2
twich3136
twich3136's Avatar
Re: 63" Rear spring swap
I happen to be working on the same sort of set up. I have a 99 14 sf with 3/4 hd springs from an 02ish. The springs inherently ride smoother than the 9 pack I have. They're more progressive but have a generous load capacity. Its becoming a pain to find proper hangers however. Im thinking about making my own. I haven't started yet but it can't be that hard with proper tools and some elbow grease. I suppose your springs choice will depend on how often you intend to haul. The 1/2 ton springs with bags might suit you better if your not going to haul that much.
USMC
SEMPER FI
68 Chevy Longhorn 350/400 factory posi
twich3136 is offline   Reply With Quote
Old 08-12-2013, 08:14 AM   #3
OLDCHEV4X4
OLDCHEV4X4's Avatar
I did the 64" spring swap on my Blazer. Different truck ,but sam concept. Check it out here--> http://67-72chevytrucks.com/vboard/s...d.php?t=480181
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 08-12-2013, 09:33 AM   #4
'63GENIII
'63GENIII's Avatar
Thanks for the replies. I'm still waiting to hear back from the seller though I'm leaning towards the HD springs and removing a couple of leaves. Burn..... those rivets are giving me nightmares already as well as the new hangers. It looked like your new hangers came from the donor truck?
Chris
'63 k15 long step
