08-20-2013, 10:38 AM | #1 |
WANTED- 1966 6 cyl FAN SHROUD
Looking for a good used or NOS 1966 Six Cylinder Fan Shroud. PM Me if you have anything available . THANKS !! Jon
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
08-22-2013, 11:11 PM | #2 |
Re: WANTED- 1966 6 cyl FAN SHROUD
pm sent
08-27-2013, 11:23 AM | #3 |
Thanks for trying Travis. I should mention its a plastic shroud Im looking for . TTT
08-27-2013, 10:04 PM | #4 |
I thought the six cylinders were a round metal type and the V8's were made of Bakelite material.
08-27-2013, 11:13 PM | #5 |
The six cylinders were also the same material as the V8s, the round metal type is generally the 60-62 V8 style. Only time you see a 6 cylinder shroud is with the heavy duty cooling option. The gold 66 K20 in my avatar has its original shroud with the 292. I will try and post pictures. I need another shroud for a truck I just bought. Its a factory 292 with the 5 blade fan, double belt drive for the water pump and Heavy duty cooling on the spid sheet but the shroud has been lost by PO.
09-01-2013, 12:13 PM | #6 |
09-01-2013, 12:47 PM | #7 |
ahhh- it's thinner than the V8 ones
09-04-2013, 04:47 PM | #8 |
pm sent
09-15-2013, 10:47 AM | #9 |
ttt
10-04-2013, 09:23 AM | #10 |
ttt
10-25-2013, 10:50 AM | #11 |
ttt
11-07-2013, 10:07 AM | #12 |
Still looking for a six cylinder fan shroud, any ideas ?
11-17-2013, 02:41 PM | #13 |
Anybody ?
12-27-2013, 08:21 PM | #14 |
Still looking
12-28-2013, 02:07 AM | #15 |
i think ones right under your nose, check out "budnikguy" 1966 parting out. the C30 has that plastic shroud,but im sure its gonna need some repair the top look chipped off its the 11th pic down. hope this helps
12-28-2013, 02:11 AM | #16 |
sorry just noticed you all ready PM'd him did you get it?
12-28-2013, 11:03 AM | #17 |
Thanks for any leads but no I didn't buy that one. Im looking for a decent used or perfect NOS one. Small cracks I could deal with but not missing pieces. Budnikguy was very helpful with supplying excellent pictures. Thanks again, Jon
12-28-2013, 06:55 PM | #18 |
Anytime, I got a question. I just got a oem fiberglass one for $50 Do you think if I apply fiberglass mat pieces and sandwich it under pressure it will come out descent
12-29-2013, 02:51 AM | #19 |
I'll chime. It could work. I had good success with a similar repair on a spare tire tub out of a Corvette. Pm coming.
12-29-2013, 03:52 AM | #20 |
Yes, pretty easy fix & good score. Those are super hard to come by in decent condition. Yours is the V8 shroud, right? Also, did all 60-66 trucks with the inline 6 come with a fan shroud or 1966 only? Curious because my grandma has an all original unmolested '65 c10 custom cab (her dad bought new in 9-1964) It has 54k original miles & it never had a shroud as far as I can tell. Truck has the 230. Thanks in advance.
12-29-2013, 10:03 AM | #21 |
Hello jon is that part number 3865486? I was looking for one for you
12-29-2013, 10:06 AM | #22 |
Yeah it's from a V8. I snagged it from a CL listing where I was able to pick through his items, he had a bunch of goodie, factory radio knobs and bracket. I got the clamp/support thing from behind the 2speed blower motor knob, not the plate, but the bracket that holds it in place, oem bumper bracket bolts, oem hood bolts with washer and a few other bits they don't sell aftermarket Then as I always do when I'm picking I was like u got a fan shroud, to my utter surprise he said I have one somewhere, OMG I kept calm cu. those thing are not easy to find and when he pulled it out, a sun ray beamed on him and he and I were kinda floating on air needless to say he didn't know what he had, I was honest and told him, but he said he wasn't gonna use it OMG the sun ray beamed on him again. Anyway I spent $140 with him and gave him a set of SS windshield trim with only one clip and a set of 63' style sail panels As I wasn't gonna use em and he is an ebay seller. Sorry I couldn't help on your shroud search I know 60-66 may know or can lead u in the right heading.
12-29-2013, 01:25 PM | #23 |
Yes that's the one, NOS would be fantastic. I actually need two. My 66 Panel was factory heavy duty cooling and my 66 short bed is a 292 AC truck. THANKS !!
12-29-2013, 01:31 PM | #24 | |
02-21-2014, 10:12 AM | #25 |
ttt
