Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 08-21-2013, 01:10 PM   #1
jerry73
Alternator wiring...not charging
I have a problem with the alternator not charging the battery ,anyone have a diagram or clear pictures of how the alternator is wired?
jerry73 is offline   Reply With Quote
Old 08-22-2013, 06:29 AM   #2
panhandler62
Java Mechanic
panhandler62's Avatar
Re: Alternator wiring...not charging
There are a number of diagrams in the "stickies" above. If you have trouble finding something people here can help but we'll need to know more details about your tuck to find the correct information.
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 08-23-2013, 11:34 AM   #3
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Try these,
http://forum.73-87chevytrucks.com/sm...?topic=11766.0
pick the one that applies and click on it then click on the diagram and the magnifier will enlarge it. The 77 to 80 SBC one seems to show the wiring pretty well but I didn't see one with the key switch in it.
Most of these trucks were wired the same in that,
The large red wire from the alternator goes to the starter and ties into the large cable through a fusible link.
The no. 2 terminal on the alternator has a red wire that also runs to a positive battery connection which is hot anytome the battery is connected.
You can be pretty sure that the no.1 wire a brown wire will go through the firewall and run to the ignition switch. If you have a charging light instead of a battery gauge it may go to the dash and tie into one from the ignition switch. This brown wire will have a resistance somewhere in it which turns on the alternator regulator and protects the diode trio inside the alternator.
The resistance also prevents engine run on after the key is shut off.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
