Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 08-23-2013, 10:55 AM   #1
mexlokote
mexlokote's Avatar
help me engine wont start!!
I have a 1994 chevy s10 blazer 2wd with 4.3 engine
i did a lower and upper intake gasket change and valve cover gasket change.
i did everything very good and i reinstalled the distributor where it was when i pulled it out,
now its all put back together and it will not start,
it turns over but no start
it makes some pop noises on the air manifold that goes from upper intake to air filter, u can hear it popping,
also i have this wire/hose? that i dont know where it goes does anyone know??
its located in the back of the distributor comes from the firewall,
thanks
mexlokote is offline   Reply With Quote
Old 09-07-2013, 09:46 PM   #2
hugger6933
Re: help me engine wont start!!
Is that the coil wire? Bring up the #1 spark plug again with the plug out and just double check, there is no shame in it. It happens to the best of us, once in a while really, if you are tired, hot or super busy. Jim
hugger6933 is offline   Reply With Quote
Old 09-08-2013, 10:18 AM   #3
jlsanborn
jlsanborn's Avatar
Double check the distributor phasing and the firing order. That hose goes to a manifold vacuum source and is used for operating the doors in you heater box.
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
