Old 08-27-2013, 09:20 PM   #1
wabash15
Daytime Running Lights
I have a chevy 2500hd and the headlights illuminate by themselves when it gets dark but the DRL do not come on at all no matter what time of day. How do I troubleshot this? I understand the truck has to be running and in gear for them to turn on?
wabash15 is offline   Reply With Quote
Old 08-27-2013, 11:13 PM   #2
5speedsilverado
Re: Daytime Running Lights
check the bulbs first, them burning out is pretty common for some weird reason
5speedsilverado is offline   Reply With Quote
Old 08-28-2013, 01:08 AM   #3
MadManAndrew
Yes, those bulbs only last a couple months at last. 99% likely they're just burnt out.
1955 Chevy 3600 http://67-72chevytrucks.com/vboard/s...61#post8589061
MadManAndrew is offline   Reply With Quote
Old 08-28-2013, 06:54 AM   #4
wabash15
checked the bulbs - they are ok
Old 08-28-2013, 08:04 AM   #5
truckdude239
truckdude239's Avatar
Have you tried new bulbs? I've looked at bulbs that looked good but where bad and new ones fixed it
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 08-28-2013, 03:05 PM   #6
69gmcc10
69gmcc10's Avatar
When I take the bulbs out to change the connectors are always burnt up a little, so check that the connection is still good.
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676
03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582
69gmcc10 is offline   Reply With Quote
Old 08-28-2013, 07:27 PM   #7
c1087
Might want to check the DRL fuse and relay. I removed the fuse in my 05 because I don't like DRLs. Also, a test light or volt meter may be helpful to check for power at the light sockets.
'76 C10 Silverado - 350/TH350
'87 R10 Silverado - 305tbi/700R4
'05 Silverado Z71 - 5.3/4L60e
c1087 is offline   Reply With Quote
Old 08-28-2013, 11:43 PM   #8
wabash15
and the solution is..... after allot of checking tonight.......2 bad sockets.
Old 09-01-2013, 12:03 PM   #9
Special-Ed
Special-Ed's Avatar
those bulbs require bulb grease... and im not joking... and the harnesses usually get all burned up...
ive replace all of my harnesses with aftermarket, and use the grease religiously and my issues have gone away.
Ed will be known as the Tiger Woods of the integration business
Special-Ed is offline   Reply With Quote
Old 09-06-2013, 12:58 AM   #10
Bowed
I recently picked up a 2000 Silverado . When the truck is running the low beam headlights and the tail lights are always on and other lights are off . It does not matter what position the light switch is in or if I set the emergency brake . There are no courtesy lights turning on either at any time . I don't have the manual for this truck and do not know if I'm doing something wrong , if the switch is bad or the PO changed something . Ideas ?
Bowed is offline   Reply With Quote
Old 09-06-2013, 01:01 AM   #11
5speedsilverado
light sensor fell into the dash on mine when it was new, also if you have a dash mat make sure your not covering the sensor
Old 09-06-2013, 01:04 AM   #12
Bowed
Wow that was a fast response . Yes there is a dash mat and I never thought about a sensor . I will check it out . Thanks .
Old 09-06-2013, 09:27 AM   #13
Crummy
Are fishermen all liars?
Crummy's Avatar
Once you fix the lights, you can bump the light switch backwards to turn them off during daytime driving. This will help with bulb life. I kill my driving lights every time I crank it. It's habit.
2004 Z71 Tahoe
Crummy is offline   Reply With Quote
Old 09-06-2013, 09:31 AM   #14
GCncsuHD
Charlie Daniels w/ a Tq Wrench
GCncsuHD's Avatar
This works for 03-07 only. 99-02 you push the dome override button 3-4 times quickly to disable auto lights and DRL.
ΜΟΛΩΝ ΛΑΒΕ
67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works
69 K5 Blazer-Family Beach Cruiser Project
78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s
SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s
GCncsuHD is offline   Reply With Quote
Old 09-07-2013, 04:42 PM   #15
MadManAndrew
4 times. On, off, on, off.
Old 09-08-2013, 11:56 AM   #16
Bowed
I checked the light sensor and it's not covered or dirty . Here is a recap of what is going on . When I first start the truck with the emergency brake applied all lights are off . When I release the emergency brake .. the low beams , parking lights , tail lights and dash instrument lights all come on . Once the lights come on , reapplying the emergency brake has no effect on turning them off and neither does the light switch itself . If I press the dome over-ride 4 times , all lights go off and then the light switch will work normally . If the light sensor was bad would it do this ? On start up with the emergency brake applied is the light sensor put in over ride mode until the E-brake is released ? Does pressing the dome-over ride 4 times shut off the light sensor and put on/off control in manual mode ?
Old 12-01-2013, 05:03 PM   #17
solidaxel
solidaxel's Avatar
There are two filaments in the bulb, which is the DRL and what is the other filament for??
Looking to test with a VOM, but what controls them?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 12-01-2013, 09:30 PM   #18
5speedsilverado
look at the wires on the socket, there are only 2 wires thus the dual filament bulb is there just cause. the reverse bulbs are the same way on these trucks.
