Old 09-14-2013, 12:25 PM   #1
Cavscout
C-Notch and shocks needed? Adjustable tracking bar too?
Just installed a set of 4" drop coil springs in the rear of my 70 LWB, the shocks I bought from Amazon don't fit so I need advice on which shocks to buy, LMC has drop shocks for $50 each.
Do I really need to C-Notch the frame with a 4" drop? My truck has the auxiliary leaf springs and I'm thinking this will be enough?
Last question, tried to install an adjustable tracking bar after the drop springs and the bar seems to be about 2" too long, the axle seems to be aligned correctly, do I need the adjustable tracking arm?
Cavscout is offline   Reply With Quote
Old 09-14-2013, 01:11 PM   #2
cdowns
cdowns's Avatar
Re: C-Notch and shocks needed? Adjustable tracking bar too?
no u do not need a c notch for 4" drop springs// the shock relotation kit is worth the effort for proper shock angle// most vendors carry a selection of drop shocks for that application// adjustable panhard is good for centering the rear in the proper location
those overload leaf springs might not allow the coils to settle for the full drop effect/// i always got rid of them on dropped trucks i had
Old 09-18-2013, 03:54 PM   #3
Cavscout
Thanks Cdowns, I didn't measure the axle to frame before I lowered it, how/where do I measure from to know my axle is centered?
Old 09-18-2013, 04:16 PM   #4
cdowns
cdowns's Avatar
sidewall of tire to the frame rail// measurement should b the same driver and passenger side
Old 09-18-2013, 09:54 PM   #5
slow-1
slow-1's Avatar
I have the helper springs too, was wondering if anyone ever altered them so you could leave them on with drop springs for hauling.
I thought if you cut a metal wedge and drilled a hole in the middle for the bolt it would change the angle and raise the end of the helper spring...just a thought.
1972 Cheyene C-10 "Ole Green"
My Grandfathers truck (early 70's to 1983)
My first vehicle (1983)
Original 350 (3 rebuilds)
700R4 from Bowtie Overdrives
slow-1 is offline   Reply With Quote
Old 09-19-2013, 10:03 PM   #6
BigRed76
BigRed76's Avatar
Most likely you got the wrong adjustable trac bar. I ordered mine from CPP and they failed to tell me ahead of time that they sell a 24" and a 27" bar, so I ended up getting the wrong one.
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
