Old 09-14-2013, 10:27 PM   #1
TheSeeker
Cool Alternator Upgrade ?
Hello All, I am going to upgrade my alternator to a higher amperage when I add AC and a newer radio. I searched summit and came up with this page
http://www.summitracing.com/parts/tf...engine-type/l6
I have a 250 inline 6, 69 c-10. Am I correct that this will work for the alternator upgrade instructions found in this thread? http://67-72chevytrucks.com/vboard/s...d.php?t=119379
If not, can anyone who has completed this upgrade offer any advice? Im looking for 80+ amps. Thank you!
TheSeeker is offline   Reply With Quote
Old 09-15-2013, 12:41 AM   #2
jcd9730
jcd9730's Avatar
Re: Alternator Upgrade ?
I've got one just like that. I dunno if it puts out 100amps like its advertised, but it powers everything including strong headlights, an alpine amp and speakers just fine. I have a 350 without AC, but I'm positive it will run a compressor when I get to that. It always squeals for a split second on startup though.
I followed that thread and it was real easy (I did eventually get the MadElectric kit though).
Josh
72 C10, 350/2004r, Porter Steel Pacs, and 40+ years of leftovers from strange POs...
jcd9730 is offline   Reply With Quote
Old 09-15-2013, 05:16 PM   #3
TheSeeker
Thats great! Thank you, I will either use this one or the 78 amp one I found at oreily. What is the madelectric kit? I saw a board member sells wiring harnesses for headlights and alt upgrades but those are a little steep for me right now at 90 bucks.
Old 09-15-2013, 10:35 PM   #4
jcd9730
jcd9730's Avatar
http://www.madelectrical.com/
I dont remember his prices, but I did his full kit though, and it was a very good upgrade. He also has some very good info on all things electrical, including alternators, so even if you dont buy, the tech section is worth a look
Josh
Old 09-16-2013, 01:07 AM   #5
In The Ten Ring
Good thread! I may upgrade my alternator too.
Does one normaly run well (alternator) if the truck has set several years?
In The Ten Ring is offline   Reply With Quote
Old 09-16-2013, 10:58 AM   #6
jcd9730
jcd9730's Avatar
It is likely, but you will be far better off going to an internally regulated alternator than deal with those PITA external regulators
Josh
Old 09-16-2013, 08:31 PM   #7
xmitsu10
xmitsu10's Avatar
I too just upgraded my alternator with this one from Skip White. http://www.ebay.com/itm/GM-CHROME-12...item4d0d64e432
At the same time, I upgraded my charging and starting system (remote starter relay) with the kits from MAD Electrical. Doubled up the fan relays for my Jeep fan and upgraded the headlight relays with fusible links and soldered connections. High quality wires and components for sure from MAD.
Mark
71 Cheyenne SWB
xmitsu10 is offline   Reply With Quote
