Used lift kit problem
Bought a 4" lift kit from CL but after installation the truck is no where near level. Has 35" tires. Any ideas as to why this is? Thanks.
Posted via Mobile Device Last edited by Tito19; 09-15-2013 at 05:37 PM. |
Re: Used lift kit problem
kit was not designed for that heavy utility body// get a fleetsede bed and it will probally raise the rear a couple inches
Does the front look like it's lifted 4"? I really want to keep the utility bed, do you think 6" blocks would level it out? Thanks cdowns.
My thought is to get the rear springs re arched and rebuilt. The rear springs appear to be original [40+ years old]. Your truck is a work truck with a utility bed. I know my work truck is always over loaded with tools and parts! PLEASE tighten down the front U bolt nuts. I would not use 6" rear blocks, they can induce wicked axle wrap on acceleration, and that will only be worse with old tired springs. Also check into a dropped pitman arm off the steering box to straighten out the drag link and prevent bump steer. SWEET truck. All the best, Dirk
I don't think what your seeing is that unusual.
I installed a new 4 leaf lift kit and still had to bring the rear up another 3" to make the ride height even. Looked a lot like your truck.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
Thanks Dirk. Would new OEM leaf springs an add-a-leafs be a good option. I ask because I'm not familiar with a shop in town that would re-arch my leafs springs. U bolts weren't tightened due to me thinking I was going to have to tear everything apart, but thanks for noticing. I think I'm going to go with a new drag link.... If I can get the old one off. @Bigdav160 I sure hope I didn't just throw away money.
Posted via Mobile Device |
I second everything gvw5400 said, and seriously you need the proper raised pitman arm, they come with all the lift kits so the person you bought the stuff from didn't wanna take it off his truck if you didn't get it.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
#8 | ||
"I ain't nobody, dork."
You need the correct steering arm as well. You will have some serious steering bind if you continue to use the stock steering arm off the stock knuckle. The drag link is at too steep of an angle.
All 6" rear blocks do is add a greater chance for wheel hop. I'd look at a custom rear spring setup. That utility box is pretty heavy. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
U bolts a little loose as well,
Rather than edit my post, i should have said lowered Pitman arm.
Or a raised steering arm.
![]() Join Date: May 2001
Dang, the front springs almost look like 6" springs. I have a 4" lift and 35" tires on this truck and yours looks taller
72 3/4t Custom Deluxe 402/auto 66k Original paint 71 3/4t 4x4 Custom Deluxe 10k original miles Original paint 71 3/4t Cheyenne 402 70k original paint 72 3/4t 4x4 Custom deluxe 72 3/4t 4x4 Custom deluxe 91k original paint 72 Cheyenne/30 Dually 69 Camaro SS396 4-speed 13 GMC 2500HD Duramax I bought new 05 Jeep Wrangler "Willys Edition" 12k miles (I bought new) 85 3/4 ton 4x4 Scottsdale 33k miles original paint 86 1 ton 4x4 SRW Silverado 454 restored 80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint 95 GMC 1 ton dually 4x4 my dad bought new 95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles 2002 2500HD 4x4 regular cab 6.0L 67k miles 2002 2500HD 4x4 regular cab 8.1L 28k miles 2003 GMC 2500HD 4x4 regular cab Diesel 93k miles 67-72 Parts for sale |
I was going to say I think you have 6" springs and 4" blocks. Just get add-a-leafs to bring the rear up. 6" springs would be the best in the long run. I love that truck. I want a utility bed so bad. I've had several and feel lost w/o one.
