Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 09-16-2013, 09:39 AM   #1
BEER HAULER
BEER HAULER's Avatar
Unplanned engine/tranny swap - help?
So... I let my friend borrow my 1965 GMC 1-ton flatbed (305V6).
He called yesterday nearly crying. Apparently ran it out of oil.
So... a SBC/700R I have is what I intend to swap in.
I did a brief search here on the swap and found some info on a 67 swap.
Are the motor mounts the same? Available here?
THANKS!
1952 Chevy COE - 'Brewtus'
1948 Chevy COE
1967 Corvette for those 'need for speed' times...
BEER HAULER is offline   Reply With Quote
Old 09-16-2013, 02:32 PM   #2
mrolds88
Re: Unplanned engine/tranny swap - help?
You planning on using the truck as a 1 ton? Reason I ask is that might consider the 700R4. If you are looking for OD try a 4l80e. Use harness from a 90-93 diesel.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 09-16-2013, 03:01 PM   #3
BEER HAULER
It is just a driver now, no longer a 'work' truck. It might haul some beer but nothing heavier. I have a 700R but I think a friend has a 4L...
1948 Chevy COE
Old 09-16-2013, 09:44 PM   #4
Are the motor mounts the same for 65 and 67 or are you asking are they the same for V6 and V8? Not that I can say for sure either way. But,I do know the frame stands are different between V6 and V8
Old 09-17-2013, 10:46 AM   #5
BEER HAULER
Asking if the V8 swap is the same for my 65 as in the 67 that I found info about.
I believe I can find a factory trans crossmember from 63-87 and move it back on the frame, drill it, and bolt it in.
1948 Chevy COE
