09-23-2013, 01:51 PM | #1 |
Catch can plumbing??
I'm trying to figure out the correct way to plumb a catch can for my LS3 with TVS1900 Magnacharger. Diagrams or pictures would be great! Thanks in advance.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
09-23-2013, 05:48 PM | #2 |
Registered Truck Offender
Re: Catch can plumbing??
Are you talking the breather vent for the front gearcase of the blower? or the radiator overflow or some kind of crankcase breather / vent ??? Sorry don't know the system at all, but I'm sure someone here will have some ideas but just need to know what were talking about.
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
09-23-2013, 08:31 PM | #3 | |
09-24-2013, 06:29 PM | #4 |
I would guess you could use a vented catch can like we do with vacuum pumps. Its easy to build one out of an old rad catch can. Just put a filter on top so it can breath.
NHRA Super Street 469C It only runs 10.90 at 156 mph |
09-24-2013, 09:21 PM | #5 |
It's Better With Nitro
X2...this is what I normally use for a breather tank on vacuum pump applications...relatively easy to find and around $100 (the poly tanks are around $40).
10-04-2013, 04:51 PM | #6 |
10-08-2013, 11:04 AM | #7 | ||
10-08-2013, 08:43 PM | #8 |
Seems complicated. I just vented my valve covers. Every so often, I empty the can. It's not like I get a lot of oil. Also, I was told not to hook up to my charger, as it will suck all the oil right out.
10-08-2013, 08:46 PM | #9 |
Interesting. Magnacharger told me some oil is good for the supercharger.
10-08-2013, 10:52 PM | #10 |
10-08-2013, 11:29 PM | #11 |
Isn't that what a factory pcv system does?
10-09-2013, 07:42 AM | #12 |
Just use the valve covers
10-09-2013, 09:05 AM | #13 |
Do you mean just put breathers on them? I found this discussion in another thread:
http://www.dsmtalk.com/forums/showth...177223&page=11
10-10-2013, 08:04 AM | #14 |
Disregard my last post. I didnt read the link you posted becuase my computer locked up lol. Since I use a vacumn pump the plumbing is a little different but I think your idea would work. My concerns would be how many inches that setup will pull. I would test it to find out. I run a pop off valve in one valve cover to keep vacumn at 10 inches. You dont want anymore than that.
10-22-2013, 03:14 AM | #15 |
Yes but oil is sucked up through the pcv and into your intake. Some more than others, but the catch can set up only allows your carb or manifold vacuum to get clean air while collecting the oil picked up in a... Catch can.
Live and let live |
10-22-2013, 09:30 AM | #16 |
I understand the purpose of the catch can, that's why I'm installing one. However, plumbing it the correct way with my configuration, is what I'm needing help with. I realize that I could just vent the valve covers to the catch can with no vacuum source, but I thought that there still needed to be some meetered vacuum via a PCV to the intake. Here's what I have plumbed so far, both valve covers to the middle port on the catch can. I'm thinkin I need to bring the top port to a pcv and then to on of the vaccum ports on the front side of the supercharger. Thoughts?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 10-22-2013 at 10:02 AM. |
10-22-2013, 01:46 PM | #17 |
I'm sorry, I hope my response didn't come off as rude. To be honest I was defending you thinking someone else was questioning the idea. I skim through these and get excited when there's one I feel I can answer.lol . If you have both covers going to the can, and then can to vacuum source you should be good. I would put the pcv valve on both (or one with pcv,one with filter) covers tho because the plug in the valve will herp with not sucking up too much oil. Altho they still stuck up oil. Usually cause with performance set ups, having bigger rockers and guirdles, baffles under the covers are removed to make room and gives the oil a more direct shot through the pcv. I'm not real familiar with supercharged late model set ups, so perhaps I'm not the guy to answer. But that was my understanding for the reasoning for them on the gen1. It any block that sucking in oil and having a strong vacuum signal.
You need the vacuum source tho.
Live and let live Last edited by familyfast64; 10-22-2013 at 01:52 PM. |
10-22-2013, 03:39 PM | #18 | |
10-22-2013, 04:20 PM | #19 |
Not sure how similar yours is to my setup on my 6.2L Escalade, but I do believe it just goes directly from the vac tube on the blower to the inlet tube on the drivers valve cover, and to the intake tube ahead of the throttle body to the tube on the passenger side, no catch can.
I'd have to look closer at it, I'm working away from home right now so don't have access.
Speed is just a matter of money, question is how fast can you afford to go? 8.95@148.97mph all motor haven't tried bottle yet Sponsored by: Getz Oilfield Consulting Hard Candy Customs |
10-23-2013, 08:25 AM | #20 | |
10-24-2013, 02:30 AM | #21 |
Always a work in progress
Look on LS1tech, there is a good selection of pics for every kind of setup. I have some pics on my home computer I can send you as well.
USMC Retired Never trust a man who can't laugh at his own fart! 2010 Silverado Crew Cab 73 SWB 5.3/4l80e Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=695168 |
