Old 09-24-2013, 07:54 PM   #1
ace13733
cab light help
Alright here is my problem I have an 82 Chevy k20 it has cab lights on it but I can't get them to turn on all the bulbs are good but I have no lights, does anyone know where the wires run or maybe what to look for?
ace13733 is offline   Reply With Quote
Old 09-24-2013, 07:57 PM   #2
rs74
rs74's Avatar
Re: cab light help
The wiring runs from the lights and goes down the drivers side A pillar and the wire comes out under the dash pad I believe.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 09-24-2013, 08:04 PM   #3
ace13733
Re: cab light help
OK thanks I couldn't tell where it went do u know if there is a fuse for them?
Old 09-24-2013, 08:12 PM   #4
rs74
rs74's Avatar
Re: cab light help
Probably wired into the parking lights.
Roy
1987 R10 shortie
Old 09-24-2013, 08:29 PM   #5
tucsonjwt
Re: cab light help
I would start with the light switch on the door pillar. Loosen/tighten the nut a little while holding the center pin. Wiggle pin. These switches are not very reliable. I have aftermarket door weatherstripping which hangs up the pin and prevents the lights from going on. If you loosen the nut all the way while holding the pin you can remove the switch. It has very thin leads, so be careful. When you reinstall the switch, make sure that the pin is not turning while you tighten the nuts or the leads will get twisted inside the pillar and break. New switches are available at any auto parts store for a few dollars.
tucsonjwt is offline   Reply With Quote
Old 09-24-2013, 08:41 PM   #6
willett
Another Day, Another Dollar
willett's Avatar
Re: cab light help
There is a fuse. Check it...
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 09-24-2013, 08:49 PM   #7
motornut
78K & 79C Jimmys
motornut's Avatar
Re: cab light help
have a look at the headlight switch,I believe had a plug in there
ground to the bus bar @ebrake would be stock
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 09-25-2013, 07:31 AM   #8
TexasJeff
Don't Crush em Restore em
TexasJeff's Avatar
Re: cab light help
I would bet it is the ground, I know the ones I installed on my truck, each lamp is grounded by a screw holding the lens in place. I would make sure you have a good ground, if the rest of your parking lights are working then it is a ground issue or not hooked up.
TexasJeff
2009 Silver with Linen Interior Cadillac DTS
1990 Red with White Top and Interior Ford Mustang GT convertible
1998 Red with Gray Interior, C3500 Chevy Crew Cab Dually
TexasJeff is offline   Reply With Quote
Old 09-25-2013, 12:54 PM   #9
clapage6
Re: cab light help
mine are like this on my 83, and each light's ground was a bit rusty and not making good contact, popped of each light cover and cleaned grounds, working good now
clapage6 is offline   Reply With Quote
Old 09-25-2013, 10:05 PM   #10
BONUSCAB
Re: cab light help
my 1990 has one ground wire for all the lights. and a mouse chewed through the wires up top in the roof. I had to fish the wire from the kick panel up to the roof through the A pillar.
Few things in life will make you look stupider than putting a dollar sign after a number.
BONUSCAB is offline   Reply With Quote
Old 09-25-2013, 10:16 PM   #11
ace13733
Re: cab light help
I know how that gos I just cleaned out the heater vents In mine and a mouse had packed them all full of insulation.
cab lights, clearence lights, wireing
