Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > 67-72
Old 09-26-2013, 11:03 PM   #1
karbias
cab floor
I was wondering if any one had built a cab floor instead of buying the replacement floor from somebody. I am not doing a restoration, more like a resto mod. I know the panel is around $300 - $500, depending on where you buy it at, but I am just trying to save some money. If any one has and has link to pictures, that would be great too. Might be a waste of time to o it this way but just thought I'd ask your guys opinion.
thanks
karbias is offline   Reply With Quote
Old 09-27-2013, 02:45 PM   #2
kaycee
kaycee's Avatar
Re: cab floor
I just bought a drvs side replacement floor panel for like $40 from LMC put in what I needed and done.
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327
kaycee is offline   Reply With Quote
Old 09-27-2013, 09:43 PM   #3
karbias
Re: cab floor
I have some of the patch panels, but unfortunately my whole floor needs to be replaced.
Old 01-06-2015, 06:07 AM   #4
ScottieB
ScottieB's Avatar
Re: cab floor
go to the junk yard and buy a couple of hoods or anything that is really flat and use the metal from that to patch in a floor.
but you'll need to know how to shape it, or cut and weld a lot!
Otherwise, go to home depot and buy sheet metal.
You will still need seat mounts that work. and you'll need to replace any rust under the cab
so if you have really bad rust, take the cab off and do it the right way
69' Chevy C10
383 Stroker / TH400
275 55 r20 Wheels
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=654751
ScottieB is offline   Reply With Quote
