Old 09-27-2013, 11:49 PM   #1
1968k10blue
1968k10blue's Avatar
reverse light switch location on sm465
does anyone have any pics of where the reverse light switch is on the sm465? It would be greatly appreciated
Austin
2005 GMC Sierra 1500 4X4 4.8l V8 (Wrecked)
2003 Chevy 1500 standard cab short bed 4x4 w/ 5.3l
1968k10blue is offline   Reply With Quote
Old 09-28-2013, 04:51 AM   #2
John Pasinski
John Pasinski's Avatar
Re: reverse light switch location on sm465
The switch is on top of the transmission. (2) prong plug. Sorry, no way to send a photo. There will be a (2) lead harness with a sheathed plug somewhere in the harness near the firewall which should plug right in. It's pretty easy as the plug fits nowhere else.
A man's thoughts devise his ways; but it's GOD that directs his steps.
John Pasinski is offline   Reply With Quote
Old 09-28-2013, 01:15 PM   #3
Daner
Daner's Avatar
The top passenger side towards the back I think.
Dane
67 Chevy Fleet 250/4 speed 1/2 ton
68 Chevy 250/4 speed 1/2 ton for parts
49 GMC Grain truck 235 1 1/2 ton
76 Chevy 350/4 speed 1/2 ton
Daner is offline   Reply With Quote
Old 09-28-2013, 09:38 PM   #4
xaircav
xaircav's Avatar
Driver's side toward the front near the top. Two wire plug with boot going in.
Never use a pipe plug in place of a backup light switch or you won't be able to go into reverse. I learned this the hard way.
xaircav is offline   Reply With Quote
Old 09-29-2013, 02:11 AM   #5
1968k10blue
Thanks everyone for the replies, I will look in the morning. The reason I ask is my reverse lights don't even have a wire running to the rear so I am trying to get them hooked up. I will try to get a picture too if I find it in the morning.
Austin
Old 01-27-2014, 04:20 AM   #6
raulb24
raulb24's Avatar
you need to remove the hump inside cab to get access to reverse switch
raulb24 is offline   Reply With Quote
Old 06-18-2014, 12:17 PM   #7
rwhite692
Bringing back this thread since I am presently troubleshooting my reverse lights. I believe my reverse switch on my SM465 trans is bad/intermittent.
Does anyone have a part number for the replacement switch? I see that LMC carries them, but I'm sure it is available at a lower cost through a regular auto parts place.
My 72 Blazer Project:
http://www.67-72chevytrucks.com/vboa...d.php?t=621724
rwhite692 is offline   Reply With Quote
Old 06-18-2014, 05:48 PM   #8
rwhite692
Found it. Standard Motor Products # NS18T
$5.59 at Amazon.
light, reverse, sm465, switch
