10-01-2013, 11:25 PM | #1 |
Ls swap air intake pictures
I'm working on gathering information and parts for an upcoming ls swap I'm doing on a '80 stepside. I'm having trouble deciding on what I want to do for the air intake. I cannot find a thread on it, if there is one, can you direct me to it? If not, I'm looking for pictures of what you did on your ls swap. Thank you
A sweet 2000 Deville..... |
10-02-2013, 12:14 AM | #2 |
meowMEOWmeowMEOW
Re: Ls swap air intake pictures
Pic isn't 100% current, but the intake is still the same. Generic Silverado intake off of Ebay. Cut one side down, flip it over, and use the elbow/coupler in reverse order. Fits good and has room for the MAF without an issue. The same intake can be setup a few different ways depending on which body style and what you need to work around underhood.
[IMG][/IMG]
10-02-2013, 04:38 PM | #3 |
Old member
Here is a thread that I posted what I did with my TPI setup. Plan to use it on the LSx swap when done also.
http://67-72chevytrucks.com/vboard/s...d.php?t=593464
10-02-2013, 04:41 PM | #4 |
Boosted Member
http://siliconeintakes.com/
They've got everything you need to piece something together, no matter where you need to run it to.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
10-02-2013, 08:37 PM | #5 |
Here's what I did, It's a spectre for a 2004 Tahoe
10-02-2013, 09:24 PM | #6 |
Here is some pics of mine: I got the parts from www.intakehoses.com. and parts from www.hotrodlane.cc. Also called Street and performance. They had the MAF adapter hose and air filter.
Good luck
This is my Build A 5.3L 1965 C-10 Fleetside http://67-72chevytrucks.com/vboard/s...d.php?t=502100 |
10-11-2013, 09:02 PM | #7 |
Here is mine.
Here is a thread on it if you are interested. http://67-72chevytrucks.com/vboard/s...d.php?t=412824 Good luck. You won't regret the swap. TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
10-11-2013, 11:49 PM | #8 |
Here is mine.
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
10-12-2013, 12:13 AM | #9 | |
10-12-2013, 06:51 AM | #10 |
Old member
That's pretty slick man I like it.
